out of ideas!!!
Old Aug 22, 2010 | 08:37 AM
july1966's Avatar
out of ideas!!!
hope i can get help here,
i have just transplanted a reman. 1978 350 into a 1991 chevy truck. i got a adapter plate for the stock tbi. will start and run fine untill it reachs opperating temp. then has a slight miss at highway speeds, and WILL not idle. just dies. will start up fine, but dies again. about to go back to the carb.
i would rather use the tbi. dont know what i am doing wrong. it worked fine before the engine swap.
Old Aug 22, 2010 | 07:25 PM
july1966's Avatar
Re: out of ideas!!!
since i have replaced every gizm and gadget and hoses, and i got no reply. i figured to go against the shop tech i have been bugging, and tote apart the tb. people i think we found the problem. darn think looks like it has been at the bottom of a lake. needs new regulater. the spring itself is in 7 pieces! ha.
Old Aug 23, 2010 | 12:27 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: out of ideas!!!
You may want to try checking the ECM for codes and possibly using an ALDL cable on a laptop with WinALDL to see what is going on.
Did you swap the same size engine? Same cam, same heads? Is everything stock?
Old Aug 24, 2010 | 09:36 AM
july1966's Avatar
Re: out of ideas!!!
i have replaced or rebuilt everything for this stock tb. the engine that sits in this truck has been factory refurbished. (1978) i have no idea about the heads being the same as the engine that i pulled out of this truck, nor the cam. all i know is that they are both 350 cid. i still have the old spead bore intake on, with an adapter plate for the tb. it will idle if i remove pcv hose from tb. nothing is making sence with this at all. also replaced the ecm. i have no vaccume leaks. acts like not enough vaccume. ????????????????????????????????????????????????????????????
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
