fuel issue?
Car: 91 RS
Engine: 5.0 tbi
fuel issue?
91 rs tbi 5.0, when car starts it runs great no hesitation, both injectors have solid spray stream. If car runs for a while and i shut it off i cant restart, engine turns over will not fire, If i try several times or wait 15-20 mins it starts fine. Last time it happened i checked spark it was good, but noticed while i had someone else turn key while its cranking fuel barely drips from injectors. waited 20 minutes tried again and fired right up and injectors sprayed right b4 firing up. changed fuel filter no change. think it could be fuel pump but dont understand why it starts sometimes and not others and runs great when it starts.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Acts Fuelishly
Setup a fuel pressure gage to let you know if it’s the pump or injection problem.
Happy Racing!
Maybe I Should Have The Guys Put A Door In The Bottom Of The Car For Those Times I Roll Over
Happy Racing!
