Swapping to Edelbrock RPM intake, I have some questions.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey everybody in TBI land, I'm FINALLY getting the ZZ4 heads and cam in and my RPM intake on. My questions regarding the intake side is what has anybody who has done this swap gotten all the brackets set up. It seems that not everything is going to happily swap from the 3704 over to the RPM. The Throttle bracket looks like it needs to be raised to give proper geometry and the coil doesn't look like it will just bolt back on.For the CTS sensor I got an adapter from true value so I can screw it in to the intake. If anybody could push me in the right direction that would be awesome.
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Re: Swapping to Edelbrock RPM intake, I have some questions.
I am also interested in this swap...Please keep us posted on how it goes.....Thanks....Anyone else out there running the RPM intake???
Car: 1983 G20 Chevy
Transmission: 4L60
Fast did you have to use spacers for the Throttle bracket?
Car: 89 RS, 92 Z28
Thanks fast...Did you like it????
theshackle
Sep 17, 2020 08:26 AM
86IROC112
Aug 17, 2015 02:00 PM
