92 rs 305 Tbi simple HP gains
Old Oct 10, 2010 | 10:08 PM
Chevyfreak417's Avatar
Hey guys im a fairley new owner of a 92 camaro rs with a 305 tbi i am looking for cheap simple ways to up the ponies at my rear wheels and so far i have put an open element air cleaner in replace of the stock air cleaner and i put a non restrictive glasspack muffler on the exhaust and also cut off the catalytic converter so its just runnin from the manifolds to a glasspack. how much do you think my hp has gone up and any ideas on how to get more hp. O and i need instructions on how to remove the air injection that pumps cold air to the cat cause i cut that off so theres no need for it takin up space
Old Oct 10, 2010 | 10:22 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: 92 rs 305 Tbi simple HP gains
u really didnt gain all that much if any, the open element air filter probably helped but cutting off the cat ( is there any exhaust after the glasspack? im guesing u put the glasspack in place of the cat?) u probably lost some torque becuase freeing up the exhaust removes back presure which could cause damage to ur valves. i have a hypertec chip that i have for my 91 tbi that u can put into ur computer takes about 10 mins.. im going lsx so no use for it any more.. it modifiys ur air to fuel ratio, trans shifting points and fan temp. i would also go with a 160 degree therostate if installing this chip.. u really dont notice the power gain from the chip right away but drive it for 2 months then take it out and ull notice that its not there lol.. ill give it to u for 50$ shipped.. also if u want to feel some exta power when u get on it i would say get some 3.73 gears in ur rear end..
Old Oct 10, 2010 | 10:27 PM
Engine: ls1 soon
as for the pump u need a delete pully,might be able to get away with getting a fan belt for the same motor just without ac but not sure.. and yea u will notice that.. same as if u took off the ac pump.. the less ur motor has to work the easyier it will run.. just crawl under there and take a look at the brackets should be able to unbolt it easy might need to take off another bracket to be able to get to it but not hard just get in there and get dirty, thats the best way to learn in my opinion.
Old Oct 10, 2010 | 11:21 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
You wont really burn your valves by running a short exhaust....
Old Oct 10, 2010 | 11:55 PM
I might actually be interested in buying that chip and i am running 6 feet of flex pipe behind the glasspack
Old Oct 10, 2010 | 11:56 PM
Old Oct 11, 2010 | 12:30 PM
Engine: ls1 soon
i wasnt stating that the valves would burn cuz of the short exhaust i was meaning because of the lack of back pressure.. if u want the chip just pm me and we can set something up
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
