TBI Injectors
Old Oct 16, 2010 | 04:41 AM
jay173's Avatar
TBI Injectors
Will 5.7 tbi injectors work in a 5.0 by just dropping them in without modifications. They are a lot easier to find.
Also where the heck can I find a tpi setup are they expensive.
Old Oct 16, 2010 | 07:28 AM
InjectorsPlus's Avatar
Former Sponsor
Re: TBI Injectors
I have those injectors for the 305. Will they work, not without a re-tune. You'll be a bit rich at idle. I'm not totally versed in TBI maybe someone can comment on if the ECU will support the larger injectors.
Why swap to TPI? IT's expensive.
Old Oct 16, 2010 | 08:37 AM
jay173's Avatar
Re: TBI Injectors
Well I always thught they used the same ecu and the 55 injectors are not much bigger but would I thught maybe it would run better.
Old Oct 16, 2010 | 08:57 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: TBI Injectors
I concur with the above advice, you are better off to first get yourself an ALDL cable & an inexpensive program like TunerPro-RT so you can get a look @ what is happening w/your engine, this is a fantastic diagnostic & tuning setup, that can save you lot's of time & cash in the long run.
It never hurts to consider the injectors for improvement as the stock ones can be quite mis-matched from the factory & over time, become dirty drastically affecting performance.
Consider instead, replacing your OE injectors w/a set that have been professionally cleaned & matched for your application.
Add an adjustable fuel pressure regulator & you can make quite reasonable strides in getting the most from your engine.
Injectors Plus offers such units, as well as a company called WitchHunter
A quick Google search will take you to either company's website where you can find their services offered & prices.
Your ECM will have no problem supporting larger injectors should in the future you make engine modifications requiring such.
Again as stated above, this requires the ability to tune the ECM.
Old Dec 1, 2010 | 04:40 PM
larry88ttops's Avatar
Car: 1988 Camaro w/T Tops
Engine: 305 TBI
Transmission: Borg-Warner 5 spd
Re: TBI Injectors
I just spoke with the tch folks over at CFM-Tech.com about thisd same topic. They do not recommend replacing 5.0 injectors with 5.7 injectors unless you recalibrate your ECM. They said that it won't know about the larger injectors unless you do this step. They sell refurbished injectors, but they are flow matched to within 1% of each other. Their price on these is $169.95 for the pair - not bad.
Old Dec 2, 2010 | 06:32 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: TBI Injectors
The LO3 stock injectors are 55#.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Keith5
Aug 27, 2015 04:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
