Which fuel pump for what I'm doing?
Old Oct 25, 2010 | 08:53 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
It's a 305 5 speed car, free mods, exhaust.
I want something that will last for a while. The car is road race and autocross set up.
Will eventually get vortec heads. That's about it.
So what brand size will be good for a stockish car that does this type of racing ?
Old Oct 25, 2010 | 09:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Which fuel pump for what I'm doing?
A stockish type pump will be fine.
Old Oct 25, 2010 | 09:24 AM
Axle/Gears: G92
Yes, but is there a aftermarket one better then the stock one? Or should I just put a stock one in?
Old Oct 26, 2010 | 05:46 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Stock ACDelco would be my first choice.
If you plan on upgrading cam and heads sometime, go with the ACDelco TPI fuel pump, so you will not have to drop the tank again.
Old Oct 26, 2010 | 08:34 AM
Axle/Gears: G92
Are they the same from the 305 tpi to the 350 tpi?
Also it will work fine without the heads and cam for now right?
Old Oct 26, 2010 | 01:22 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Tbi pumps i think only run at 15 psi max, tpis are higher, just get a replacement tpi fuel pump and put it in, imo the first thing when moding a tbi should be upgrading the fuel pump so u know ull have enough fuel preassure for mods.
Old Oct 26, 2010 | 01:50 PM
Axle/Gears: G92
The pump Is the same from 305 to 350 tpi right?
Old Oct 26, 2010 | 02:11 PM
DSGx's Avatar
Engine: 305 TBI L03
Yeah i think they are the same.
Old Oct 26, 2010 | 06:04 PM
thomas1976's Avatar
Car: 91 Trans am
Exsternally they are the same.
EDIT: Sorry I did not pay anoug attention and though you were talking about TPI and TBI fuel pumps.
YES 305 and 350 TPI fuel pumps are the same.
Old Oct 26, 2010 | 06:17 PM
Axle/Gears: G92
So If they aren't internally should I get a tpi 305 or 350 pump
Old Oct 27, 2010 | 05:44 AM
thomas1976's Avatar
Car: 91 Trans am
Yes 305 and 350 TPI fuel pumps are the same.
Here you can find the part # for the TPI fuel pump I am using.
https://www.thirdgen.org/forums/tbi/...ml#post3975608
https://www.thirdgen.org/forums/tbi/...fuel-pump.html
Old Oct 27, 2010 | 11:31 AM
Axle/Gears: G92
Thanks for the links!
Old Oct 31, 2010 | 11:17 PM
Axle/Gears: G92
Are you sure a stock regulator will hold the pressure from a tpi pump?
Old Oct 31, 2010 | 11:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A stock regulator doesn't "hold" pressure, it shunts excess volume back to the tank.
Old Oct 31, 2010 | 11:44 PM
Axle/Gears: G92
Ok, that doesn't Aswner my question. Will it be ok?
Old Oct 31, 2010 | 11:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
Old Nov 1, 2010 | 04:25 AM
thomas1976's Avatar
Car: 91 Trans am
Will probably show a 1-2 psi increase to the injectors.
Best is you get/make an Adjustable FPR, to adapt fuel supply to your modded engines demand.
Of cours tuning is required wenn changing fuel supply, the best for this is http://dynamicefi.com/
Though if cam and/or heads are not upgraded and the current pump is not shot, it is not necessary to change the fuel pump.
The TBI pump works perfect and is wery reliable.
Another way to increase fuel supply, with the stock fuel pump, is to use injectors with higher flow rate like 61, 65, 68, 80, #90 lb/hr, ...
Again tuning will be mandatory.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
