cant find nothing that will fit for my TBI
Old Oct 26, 2010 | 10:31 PM
kanaka4rmcali's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
right now i have a stock cold air intake on my 90' camaro and im lookin for a cold air intake kit, and all i can find is a dual Spectre cold air, but looking for more options. so dose anyone know of any good cold air kit or any recommendations.
Old Oct 26, 2010 | 10:43 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: cant find nothing that will fit for my TBI
better off building ur own.. been there tried to find it no luck
Old Oct 26, 2010 | 10:51 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
well they dont technically sell one for our cars. a lot of people have been taking the tpi air boxes and using them as an air box for cold air induction do a search on it and you'll see them.
Old Oct 26, 2010 | 10:54 PM
Car: 1990 Camaro RS
Engine: L03 305 TBI
what brand did you buy your parts from to build it, and did you have enough room for a dual intake or did u just do a single?
Old Oct 26, 2010 | 10:57 PM
Car: 1990 Camaro RS
Engine: L03 305 TBI
yeah but if you use a tpi box can you get as much hp compared to a built cold air intake for tbi?
Old Oct 27, 2010 | 06:07 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I doubt the factory camaro TPI air cleaner will anyhow be restricting on a LO3, since the stock TBI aircleaner is not really restricting it.
The 170hp @ 4400 rpm LO3 engine is not exatcly a air hog, though a nice air cleaner could still be nice to have.
The TPI air cleaner can also be modded, somewere in the TPI or fabbrication forum there is a high flow air cleaner lid tread covering it. With a little search you will find it.
Here are some other examples of DIY cai.
https://www.thirdgen.org/forums/tbi/...l-diy-tbi.html
Old Oct 27, 2010 | 03:06 PM
Ronny's Avatar
Spectre stuff. KN AC Available summit, jegs or ebay. be creative.
Old Oct 29, 2010 | 11:02 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Izz that your vett w/the squeeze Ronny?
Old Nov 1, 2010 | 11:37 AM
Ronny's Avatar
yes...
Old Dec 10, 2010 | 05:26 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Ronny,Hey i like that cold air setup man
Im looking at Spectre stuff and i cant seem to find a similar cover other than the one on this dual intake http://cgi.ebay.com/ebaymotors/DUAL-...Q5fAccessories
Old Dec 10, 2010 | 05:34 PM
OH! and this!
http://cgi.ebay.com/ebaymotors/Spect...Q5fAccessories
I think thats it right? You just extended the length?
Old Dec 13, 2010 | 09:06 AM
Ronny's Avatar
EBay....comes in 2.00 inch height and 4 inch. I nneeded 2 in and a riser of (2) x .50 inch. plastic cracked alum riser did not.
Old Dec 14, 2010 | 01:38 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
TPI airbox will supply more than the L03 could ever pull, unless you go to a big cam and aftermarket heads/induction. The airbox itself isnt a restriction so much as the air filter elements as theyre kinda small. Even K&Ns are a little restrictive on my 350. Ive pulled around 600 CFM of air thru the box and I see around 2 in Hg of vacuum with K&N filter elements. The L03 only probably pulls around 350-400 CFM, so it wont be a restriction.
One word of caution is that TBI does not work well with very cold air. You will get stratified mixtures if you run the TPI airbox in the winter. One option is to simply put an open element on the end of the carb hat so you pull warm air off the radiator.
Old Dec 14, 2010 | 01:28 PM
Ronny's Avatar
I noticed that when I ran a 75HP shot of N20 early this fall. Shows up on WB. I think I need to reserve that fun for summer.
Old Dec 14, 2010 | 09:29 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah someone on here put the tpi airbox and then used the stock air cleeaner housing as the filter. Im sure you probably saw it. I think they ran the truck lid so they could get a taller filter. I liked that setup
Jeremys87
Jul 14, 2022 09:08 PM
evilstuie
Jan 9, 2020 08:29 PM
armybyrd
Aug 10, 2015 09:23 PM
