Want to install fuel pressure gauge.
Old Oct 31, 2010 | 01:39 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Were is the best place to install one in my TBI bird and who sells adapters if one is needed, i want to install this gauge so it will be permanent not just to test fuel preassure, im gonna be buying an adjustable fuel preassure regulator soon and i want to know at what preassure im setting it so yeah. I know i can make my already stock fuel preassure regulator adjustable but i dont want to mess things up.
Old Oct 31, 2010 | 01:59 PM
DSGx's Avatar
Engine: 305 TBI L03
Re: Want to install fuel pressure gauge.
I think i found the adapter, will this work guys ? http://marine-performance-parts.com/...843505774.aspx it goes were the stock fitting goes and has two ports for whatever accesories u want to hook up to it.
Old Oct 31, 2010 | 02:22 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Try this,...them other guy's..well..let's just say..if you don't know better..
They have printed some real poo on their site.
http://www.rvmorsemachine.com/newproducts.htm
I ran -8 braided line from the tank so I put a normal -8 tap under the rig for Autometer's 2246 electric sender.
Old Nov 1, 2010 | 05:44 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
This is probably the best way to mesure FP, thoug its better to remove the gauge once set. https://www.thirdgen.org/forums/tbi/...sure-test.html
Old Nov 1, 2010 | 06:27 PM
DSGx's Avatar
Engine: 305 TBI L03
So u used this adapter ? http://stores.ebay.com/TBIPARTS_TBI-...=p4634.c0.m322 and instead of putting it behind the TB u mounted it were the rubber line meets the metal line that goes to the injectors, that adapter is a direct bolton right ? I wont need any kind of special fitting to match the threads ? Gauge goes on the feed line right ?
Old Nov 1, 2010 | 08:33 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah im upgrading to a Holley tbi and im ordering from RV morse to get a fuel pressure gauge on it so I can adjust. You can use the tbi parts one but mounting a gauge permanently is more difficult. I guess. I own a fuel pressure tester but it just seems easier to pop the hood and look!
Old Nov 1, 2010 | 08:57 PM
xch3no2's Avatar
Transmission: TH400
Yes that is the adapter shown on thomas car. It is for a pressurized line,
and connects as you said.
You were talking about an adapter for permanent installation.
Most of us would assume that you wanted a gauge mounted in the passenger cabin.
Nobody in their right mind is going to advise you to install a pressurized fuel line in the passenger cabin, no way, no how.
You wanna live life on the wild side that bothers me not, I strongly advise you to mount any pressurized line/gauge OUTSIDE the passenger cabin for obvious reasons.
Gauges inside are to be either electrical or connected via an isolator & glycol filled line.
Old Nov 2, 2010 | 12:50 AM
DSGx's Avatar
Engine: 305 TBI L03
No , this adapter http://cgi.ebay.com/ebaymotors/TBI-T...Q5fAccessories can it be installed were the rubber line meets the metal line under the hood? If yes can it stay there with a gauge mounted to it or not ? I dont care if i cant keep the gauge there or the adapter , all i want is a way to know at what psi i want to set the system at after that i can just take it off and be done with it.
Old Nov 2, 2010 | 05:29 AM
thomas1976's Avatar
Car: 91 Trans am
Check out the "actron kit" xch3no2 posted in the "fuel pressure test" tread.
Can fit the T permanently as described, hook up the gauge only wenn mesuring fuel pressure.
The kit doesn't come with a cap for the T, but you can find a cap that fits.
The gauge has a long hose that allows to put the gauge under the wiper, this will help observe FP under load. (remove the gauge and hose after testing, do not test for over 3 minutes by driving, keep the hose away from the exhaust and engine. WERY IMPORTANT! if not BBQ)
I would not put a gauge permanently on the T adapter, at the rear of the TB or next to the alternator, doesn't matter.
For detailed questions about a particular part, contact the seller.
Old Nov 2, 2010 | 09:56 AM
DSGx's Avatar
Engine: 305 TBI L03
Ok thanks for explaining , yeah like u said im not gonna leave the gauge on, just for testing, so this kit http://www.summitracing.com/parts/SUN-CP7817/ will work right ? What about the one posted that is sold at Advance http://shop.advanceautoparts.com/web...537-_-10720525 this one is a different part number but on the picture it looks like the same thing, u think thatone has the T adapter ?
Old Nov 2, 2010 | 10:23 AM
DSGx's Avatar
Engine: 305 TBI L03
Hey btw thomas going offtopic here but since u have a nice TBI setup on your car i figured u could know something, what numbers do you think ill be able to push out of my stock 305, with a full 2.5in exhaust system from headers to tips , EBL tuned and with an intake upgrade(gonna swap a carb intake with the adapter) and ofc with a afpr. I figured atleast minimun 20-/+ HP could be squeezed out of the stock motor without having to swap heads and a cam, also a change in torque. Or i dont know since this motors came with such restrictive everything i think freeing up intake and exhaust and paired with a more appropiate tune this motor could make more than 20 extra horses from those boltons alone.
Old Nov 2, 2010 | 10:33 AM
xch3no2's Avatar
Transmission: TH400
The kit shown on the Advance Auto site does NOT contain the correct adapter part (T) for TBI pressure testing. (the gauge is the same)
That kit (7818) would be used for testing a TPI system w/test port on the fuel rail.
Do some Google or Amazon shopping for the CP7817 (the correct kit) for your best price information.
Old Nov 2, 2010 | 01:14 PM
DSGx's Avatar
Engine: 305 TBI L03
No im gonna get the one u posted from summit ty.
Old Nov 2, 2010 | 06:47 PM
thomas1976's Avatar
Car: 91 Trans am
Your estimation seems should be correct, though the intake manifold will not make a big difference.
Wenn I put the performer TBI intake on the LO3, absolutely no noticeable difference, though I never tried the carb intake.
Here are some # from other members posted by gray goose.
https://www.thirdgen.org/forums/tbi/...bi-3704-a.html
Old Nov 2, 2010 | 08:11 PM
DSGx's Avatar
Engine: 305 TBI L03
Yeah i have noticed , the edelbrock performer is just a tad better flowing copy of the original. If you know what is the part # of the carb intake with an EGR port that will bolt on, i think its an edelbrock too dual plane manifold. Is this the one ppl use ?
http://www.summitracing.com/parts/EDL-3701/ Also found this Holley http://www.summitracing.com/parts/HLY-300-66/?rtype=10 wich is made for TBI so no need of adapters, it comes with 2inch bores i think so it seems like a better deal.
Old May 14, 2011 | 12:00 AM
babyblue's Avatar
where do you connect the fuel pressure gauge to test the fuel pressure on a 91 camero tpi with a 305 engine
92camaroJoe
Jul 29, 2023 07:57 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
