Heater/AC won't shut off.
Old Nov 10, 2010 | 07:17 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I can't get my heater/AC to turn off when I am done using it. It continues to blow air either out of the vents, or from the floor. Should I be looking for a vacuum leak?
Old Nov 11, 2010 | 01:17 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Heater/AC won't shut off.
on my 89 buick i had that problem.there was an electronic module that went bad.of course the buick was climate controled so it may be different.
Old Nov 12, 2010 | 07:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Are you turning the slider to the OFF position? If the slider is anywhere but OFF, the fan will still blow even with the **** turned all the way to the left.
Old Nov 12, 2010 | 09:25 PM
Engine: 350 S/B
The slider is set to off and still getting air out of the vents, and or floor vents.
Old Nov 19, 2010 | 07:25 PM
Engine: 350 S/B
TTT
camarohelp
Sep 22, 2015 03:19 PM
wisemanz28
Sep 20, 2015 01:26 PM
RedIrocZZ
Sep 19, 2015 02:22 PM
david068513
Sep 18, 2015 10:36 AM
Fronzizzle
Sep 8, 2015 12:10 PM
