Weird sound when i open the gas cap.
Old Nov 22, 2010 | 03:26 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Ok so i havent bothered with this since i always was thinking that this is normal but no other car that i know of does it, everytime i open my gas cap i get a shhhhh sound out of the tank, i know its gas preassure being let out but why is my tank under so much preassure then ? I got the canister in the engine bay and its all connected tho the canister itself looks like the PO replace it with a junkjard one since it has all the typical junkyard writings all over it. So is this normal on thirdgen TBIs ? The other day i went to start the car and it died twice , fuel was not getting to it, and i could hear bubling inside my fuel tank or atleast thats what i think it was but it did sounded like someone blowing bubles like when u blow into a glass of water with a straw, the third time it cranked right up and has been ok ever since, can the gas cap be causing this, i think its a replacement since its not attached to the car anyways it just comes completely out and does the cracks when i screw it in all the way so the cap is a direct replacement if it was ever replaced.
Old Nov 22, 2010 | 03:50 PM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
Re: Weird sound when i open the gas cap.
Sounds like you are building a vacuum in your gas tank. The shhh could actually be air rushing in. I had something similar when in my TPI a check valve stopped working. I would get the shhhh noise or if i drove it from full tank to full empty i'd get a shhhh and then a light thunk from the gas tank sheet metal popping back into place.
Old Nov 22, 2010 | 04:57 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
You have a vent valve coming off of your tank connected to a hose about 6-12 inches in length. Could be plugged...
Old Nov 22, 2010 | 08:59 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
normal ........
Old Nov 22, 2010 | 10:44 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Originally Posted by UNCLE TOM
normal ........
yup.
my car never did this until 2 years ago when I had to pass smog and found a crack in my filler neck area. reparied the crack and then it hissed afterwards when i removed my gas cap after driving. before this i always smelled fuel but never knew from where.
Old Nov 22, 2010 | 10:47 PM
Stephen's Avatar
Car: 87 GTA
normal ........
When it DOESN'T "shhhh" is when you need to start looking into it. Means something is leaking somewhere.
Could just be a bad cap.
Old Nov 23, 2010 | 12:52 PM
DSGx's Avatar
Engine: 305 TBI L03
thx for the answers guys , i guess its normal then cuz my car does the shhhh when i open the gas cap so i guess all is normal, now what it did the other day was weird that bubling inside the tank got me worried it did it when the pump was priming but i didnt hear the usual sound the pump makes when it primes instead i heard that bubling lol, was it running in the wrong direction and making fuel go the other way out the feed like ?
Old Nov 23, 2010 | 05:01 PM
Keith5's Avatar
Car: C1500
Every thirdgen I ever had built the vacuum in the tank like that from day one. As said before, that is normal.
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
BurlyChev
Aug 16, 2015 09:08 PM
gwade12
Aug 8, 2015 08:17 AM
