How do I access my data log?
Old Nov 30, 2010 | 07:15 PM
y5mgisi's Avatar
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
I cant seem to figure out how to gain access the text file of the data log that i just did using winaldl. Where does it get saved to and what does it save as?
Old Dec 12, 2010 | 04:40 PM
JeepYJv8's Avatar
Car: 1992 Jeep Wrangler + a few more car
Engine: Gm 5.7 T.B.I with 1227747 ECM
Transmission: 700r4 DIY built
Axle/Gears: Ford 8.8/D30- 4:10 and lockers
Re: How do I access my data log?
Mine is strange as well. im running win 7. i need to click computer under start menu
then
c drive
then program files (mine has 2 sets of program files. (program files) and program files (x 86)
my winaldl is located under program files (x86)
Click winaldl
then in the top menu bar there is a tab that says (compatibility files)
Click that and you should find your logs, somehow i created a shortcut from there, but i don't remember how. I hope this helps!
Falcon50
Aug 22, 2020 03:26 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
