why does my TBI bog down a little?
Old Dec 2, 2010 | 07:12 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
ok, I got my hands on a nice 89 rs, it came with a 92 lo3 engine, to make a long story short ...i took it to get a slight hesitation fixed, but instead got it back with a 2bbl carb and cast iron intake.... .. so i just put the tbi system back on via ebay, and it has a good idle, i also resealed the motor. now my problem is when i rev it and hold it a 3-4 rpm it holds it for about 1 sec and then drops a little bit, what can the problem be???
Old Dec 3, 2010 | 04:23 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: why does my TBI bog down a little?
You could start by making sure all sensor are there, the IAC is set and working, test the fuel pressure and make sure the trottle blades are not sticking.
Old Dec 3, 2010 | 05:09 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
if it has an EGR, make sure it's functional..
Old Dec 3, 2010 | 08:57 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
i got the response waaaay better, now when i'm cruising and try to stay at 30-40 mph, the car will feel like it wants to die, kinda like when you dont give it enough gas to let the clutch out, kinda rocks back and forward ,,,i just put a zoom clutch and had the flywheel turned...bled the clutch lines
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
