"Stock" tbi VRFPR pics
Old Dec 6, 2010 | 04:51 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I have been asked what VRFPR I'm using.
It's simple, staked shims are used to obtain required fuel pressure and it looks stock. http://www.turbocity.com/product_inf...roducts_id=602
https://www.thirdgen.org/forums/atta...e-dsc08258.jpg
The TB was sent to Tom Miller from Turbocity, for porting.
Attached Thumbnails "Stock" tbi VRFPR pics-dsc08618.jpg   "Stock" tbi VRFPR pics-dsc08614.jpg   "Stock" tbi VRFPR pics-vac-reg1web-001-copy.jpg
Old Dec 7, 2010 | 10:27 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: "Stock" tbi VRFPR pics
so you stack the plates on it to get more fuel pressure? I read about that and it says 17 psi is the most that it will do. How much pressure does your application use? Do you know if this will bolt onto the holley tbi unit? (i like the vacuum reference)
Old Dec 8, 2010 | 03:57 AM
thomas1976's Avatar
Car: 91 Trans am
Correct. I have used this VRFPR @ 28 psi, 24 psi with TopDownSolution's FP spring on my previous LT1 cammed LO3 and courrently @ 15 psi.
The spring rate is going to set the limit.
This is basically a "stock replacement" part for the Rochester TBI http://www.summitracing.com/parts/JET-61500/, the stock fuel pressure regulator cover can be modified to work the same way.
I do not know if the Holley TBI uses the same fuel pressure regulator cover and diaphragm as the Rocherster TBI.
Old Dec 8, 2010 | 11:05 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I gotcha. I'll compare the holley tbi to rochester since i have them laying around and see. I do have a 30 lb spring for the holley but at this point and time its overkill for my application.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
snakeshooter
Sep 7, 2015 11:15 AM
355tpipickup
Sep 4, 2015 05:32 PM
Billy Decker
Sep 4, 2015 03:46 PM
