Viewing data
Car: 1993 Caprice
Transmission: 4L60
Viewing data
I am stuck in the middle of a TCC electronic diagnosis. I followwing flow chart in my FSM and the last set of tests are to be performed with a Tech-1. Are there any program that could do the same using my laptop?
anyone with info on 4th gear switch?
Re: Viewing data
Yup! All the info is in the stickys. Since we don't even know a vehicle your working on it's hard to point you in the right direction. Like if you had a 1227747 ECM in a truck you could use WinALDL and a cable from ALDLcable.com
Car: 1993 Caprice
Transmission: 4L60
Re: Viewing data
my fault man, 1993 L03 Caprice isaw that it say up to 93 caprice and f body. I saw videos of 93 using program.
will some features be amiss with my ecm?
Car: 1993 Caprice
Transmission: 4L60
Re: Viewing data
got TCC problem fixed with new temp sensor. I also installed new egr valve, IAC, delphi O2 sensor, and knock sensor. I also found a chafed evap purge solenoid wire and fixed. when I get back I am tracing each vacuum line in engine bay. I getfrom time to time a stumble/surge while at a stop lightbut only after being in closed loop for a while; like after a drive on highway or 30 mins of stop and go. I did some datalogging off tuner pro rt and not exactly sure what I am looking at. doing some searches but any direction would be great. I swapped wires as well and probably will do cap and rotor. dont know if Borg Warner or accel have any comparison, but they are within 50 cents of each other.
Abubaca
Nov 5, 2016 12:22 PM
86White_T/A305
Sep 21, 2015 05:28 PM
