cfi to tbi
Old Jan 28, 2011 | 08:17 PM
esp68camaro's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700-r4
Axle/Gears: 3.73 posi
cfi to tbi
hey guys i need to get some info on converting a cfi 82 camaro with a 700r4 to a tbi 350..got the car from a junk yard its been converted to carb and ive decided to buy a running 350 tbi for 300 bucks....need to get runnin by summer...thanks
Old Jan 28, 2011 | 11:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can put the carb on the 350.
Or, get TBI stuff from a 3rd gen member. They are taking them apart all the time. Get a 350 TBI (or injectors) and chip, should be fine.
The TBI forum may be a better place to inquire. Moving there.
Old Jan 29, 2011 | 12:53 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: cfi to tbi
Well put the motor in the car and use a tbi wiring harness and ECM and put her in. Did you get all that with the motor too?
Old Jan 29, 2011 | 07:27 AM
Car: 86 iroc-z
Engine: 305 tpi
Re: cfi to tbi
i havent bought the motor yet but wouldnt the harness connectors be different? it wouldnt be direct connection to the dash harness... if it is direct fit awesome but i dont think it would be that simple....id like to keep this fuel injected...fyi
Old Jan 29, 2011 | 09:52 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: cfi to tbi
as long as you can trace and splice wires and do minor
fabrication,the TBI swap will be easy-especially since the
car had CFI before as suitable fuel lines,VSS and other
parts are in place already.'88-89 camaro TBI harness
might be really close to direct swap,90-92 likely a little
different but probably suitable.1987-early '90s pickup
truck TBI the simplest wiring and those trucks a source
for 350 TBI chips. When i swapped a corvette 350 CFI
into my z28,i was able to remove all of the A.I.R. smog
equipment but i did keep the EGR and canister purge
active.
Old Jan 29, 2011 | 03:53 PM
ex-x-fire's Avatar
Re: cfi to tbi
I'm new here but been on the vette sites a couple years, I swapped my 84 vette from cfi to tbi about 10 yrs ago. You can use the cfi wiring harness to run the tbi. Make sure the tbi unit thats on the engine is an 87-89, as the tps sensor was different on 90 up models. My throttle/tv/cruise control cables hooked up fairly easily. Use the newer style coolant temp sensor as the ones on cfi are troublesome, just wire a connector to the harness. I also installed a dummy iac & housing because it seemed to idle better w/ 2 iacs hooked up, even though only one was controling airflow. Back then they didn't have those renegades, so this was my solution for a better flowing intake.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
