What Size injectors should i buy
Old Feb 8, 2011 | 12:46 AM
hotrodhaskins's Avatar
Car: 1988 pontiac firebird
Engine: 332sbc
Transmission: th350
Axle/Gears: 10bolt 28 spline posi trac 3.73 gea
i need help determing the size of injectors i need for me 327. I hane vortec heads with some work done to them, a custom ground cam for .500" of lift power between 2300-7200 rpm, 327 boared to a 332, gm performance intake, holley throttle body. my problem is that the holley came with 60 pd injector and i sent my computer out to get flashed but passed 5000 rpm it strugles and dies
Old Feb 8, 2011 | 04:26 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: What Size injectors should i buy
I doubt the stock ECM is adequate for your goals.
The best would be EBL flash http://dynamicefi.com/ plug and play.
60#/hr injectors would require 40 psi of fuel pressure to support around 400hp.
What is the estimated hp and what injectors are available for the holley?
Old Feb 8, 2011 | 04:32 AM
Engine: 332sbc
Transmission: th350
i sent my stock computer to get flashed and they said get bigger injectors but my cousin has a 383 almost same setup with the same injectors
stock style injectors interchange my goal is close to 400
i only run a 20 psi for fuel
Old Feb 8, 2011 | 04:50 AM
thomas1976's Avatar
Car: 91 Trans am
I don't know how holley's injectors are rated, neither what pressure they can support.
GM 60#/hr @ 20 psi would be good for 280hp and a little more maxed out.
GM 80#/hr @ 22psi are good for 400hp and a little more maxed out.
The more experienced tuners burn many chips (20-100), to get the tune right.
Old Feb 8, 2011 | 05:03 AM
Engine: 332sbc
Transmission: th350
i think i will invest into that ebl system i have sent mine out and have tested well over 20 ecm
where would i buy bigger injectors the holley injectors are rated 60pph at 12 psi
Old Feb 8, 2011 | 05:52 AM
thomas1976's Avatar
Car: 91 Trans am
60pps@12psi sounds wery similar to GM 350 tbi injectors 61#/hr @13psi.
I got my pair of flow matched 80#/hr (gm#17084304) from tgo member dctrumpet.
Maybe could find some at the JY and have them flow tested and matched. http://www.witchhunter.com/tbiremoval1.php4
http://www.southbayfuelinjectors.com/
Old Feb 9, 2011 | 11:49 AM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Some injector sizing tools,
http://www.gtsparkplugs.com/InjectorSizeCalc.html
http://www.solutions29.com/injcalc.htm
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
New2Chevy
Oct 4, 2015 11:27 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
