Spark plug removal problem
Old Feb 10, 2011 | 02:56 PM
First_Formula's Avatar
Car: 1988 Formula Firebird (deceased)
Engine: l03 V8
Transmission: T-5 manual
Got a question, this is gonna make me sound REALLY stupid and i'm sorry...
I got an L03 i got a new spark plug wire set, plugs cap and rotor. Got under the car marked the piston numbers on the distributor and everything and got to spark plugs and i absolutely can not get at the b*stards from any angle, i'm having specific problems with one, i think piston 6. Right next to the 02 sensor and i got a 3/8 ratchet and an extension on it but then the wrench hits the exhaust manifold... does anybody have any kind of tips or tricks to help me out with this? cuz its about 4 degrees and i want my car back lol
Old Feb 10, 2011 | 03:12 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
Re: Spark plug removal problem
put your car on ramps it makes it much easyer take your time the last 2 on each side you have to do from under the car i have done it 3 times now and use good plugs and wires and cap and rotor like msd cap rotor coil and wires and use ac delco rapidfire plugs they work the best
Old Feb 10, 2011 | 04:16 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I've done it more times than I can count with a 3/8 ratchet & sparkplug socket. I always have to do at least two of them from under the car.
Old Feb 10, 2011 | 07:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am a big fan of a spark plug socket that you can buy through SLP and or ebay for $10. You slip it over the plug and then can use a wrench to break them loose. I have a $9 socket that I have used with the stock manifolds, and two different sets of headers.
Old Feb 10, 2011 | 10:22 PM
Engine: l03 V8
Alright, thanks alot guys, I threw it up on ramps and got at at the last few of um, I've never owned a car you had to get under to get at the spark plugs for....
Anyway thanks alot!
Old Feb 11, 2011 | 12:26 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah these cars were the beginning of the hard spark plug changes! Not too bad once you figure it out. Next time you will do them a lot faster!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
