Weird Idle When Start
Old Nov 22, 2010 | 05:57 AM
Guest
Guest
Posts: n/a
When startng my car on a cold or hot day and even running it and driving it when put my car in park the idle goes all the way up to like 2000rpms.
why does it do this.
Old Nov 22, 2010 | 02:46 PM
Ronny's Avatar
Re: Weird Idle When Start
clean the IAC and passageway.
Old Dec 19, 2010 | 08:40 PM
Guest
Guest
Posts: n/a
Any Pics Would Help Where at thanks.
Old Dec 22, 2010 | 12:55 AM
JeepYJv8's Avatar
Car: 1992 Jeep Wrangler + a few more car
Engine: Gm 5.7 T.B.I with 1227747 ECM
Transmission: 700r4 DIY built
Axle/Gears: Ford 8.8/D30- 4:10 and lockers
Here is a pic of the TBI, as you can see the IAC (idle air Control) is located on the left rear of the TBI,there is a gasket on this part, try and not damage it when you remove the IAC. If you do damage it, either find new or buy some gasket material from local auto parts store, and make your own. in either case make sure you use a gasket.
Old Feb 11, 2011 | 11:49 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
you know mine does the same thing and ive taken apart and rebuilt the throttle body. any other things that can do this? itll rev to 1800rpm when started and rev high for 3 mins then slowly go down to 550rpm.... any ideas experts? its stumped me for 2 yrs now. just to know: all new sensors with the stock rebuilt motor. no cel or soft codes stored. new fuel pump and filter. new injectors.
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
perZ
Aug 15, 2015 01:17 PM
