Injector Bias
Old Mar 1, 2011 | 03:58 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Injector Bias
Anyone know the correct injector bias for GM#17084304*RPD injectors.
Old Mar 2, 2011 | 10:07 AM
Ronny's Avatar
Re: Injector Bias
I have never seen that posted just recomendations I recall. I presume you searched "injector bias".
I think there was a recent post that FIC Injectors responded to with there observations. May have been port fueling. They may have those #'s available to you.
Old Mar 2, 2011 | 10:40 AM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Injector Bias
Yes, I have done some searching. I have been using 274usec for the bias since that is what I had found used in most of the 454 tbi ecms. However, some recent test/scan data that I have been looking at seems to indicate this is not the correct bias for my setup.
I am not sure whether it is simply the wrong value or if my increased fuel pressure is having an effect. I am at 16 psi.
Does fuel pressure effect the injector bias? If so, is there a fixed relationship that can be used to calculate the bias based on the increased fuel pressure?
Old Mar 2, 2011 | 10:56 AM
Ronny's Avatar
Re: Injector Bias
good Q. I am with 80 lbs at 20 lbs. I dont have my lappy here office so dont know what I did 3 years ago. I am sure FP affects timing of injs. Stock EBL.bin 305cid had the 55 lbs inj at 12 lbs. I believe the bias was increased for my need. Not sure what I did.
See intro to tuning part 2 and stickies above for reference.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
