best heads combo for cam
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
ok everyone i recently bought a cam
447 lift
220 duration
wolverine blue racer cam
wondering wat heads would be best to use for cam??
or should i just stick to my stock heads
447 lift
220 duration
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: best heads combo for cam
Well a head change is deffinately should be in your interest. Now if you do not plan on changing anything later. You can use a stock head. But power will not be there. The best bang for your buck is to swap vortec heads on there and create some way to run the egr. Unless you want to delete it which you can by having a custom chip tuned. Other than that. YOu can purchase some edelbrock heads, summit heads, designed for centerbolts. They have 170cc intake runners which arent too big to outflow your rpm potential and can make okay power im sure.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I would get rid of that cam as quick as possible. A 30 $ LT1 cam with 300k miles on it will make more power.
There is also no good point for that double timing chain, except if they use crappy materials and crappy craftsmanship, that require two to make up for the lack of strengt and quality.
Engine: gone
Transmission: gone
Axle/Gears: gone
We went over this already thomas with the OP. He is not getting rid of that cam. who makes a single roller chain anyway?
Car: 91 Trans am
Hmm...no extra 100$ for a new top roller cam, now asking what heads to buy...
Anyway, flat tapped pic, 447 lift and 220 duration specs aint anough information.
Single roller chains
http://www.summitracing.com/parts/NAL-12371043/
http://www.summitracing.com/parts/CLO-9-3157/
http://www.summitracing.com/parts/CLO-9-1157/
http://www.summitracing.com/search/P...?Ns=Rank%7cAsc
Engine: gone
Transmission: gone
Axle/Gears: gone
nope. he got a deal and he will stick with the deal until he realizes it wasnt great!!
I know it doesnt make the most sense. And I am in no way trying to argue with you. Some people are stuck. and thanks for the links I had never seen those. I think the upmost of your posts and knowledge on engines btw. But just to dive into this a little more. The same manufacturers make double roller over single roller. If a single roller is suffice then why bother making the double? And Is it really a cardinal sin to run a double over a single? What kind of benefit does running just a single present over a double? The average person would see the double and think. Well its stronger, less prone to stretching so whereas the timing will stay more consistent. I can see why the original veh. manufacturer would run single's to save $$$ on cost of building cars. Why do the aftermarkers push double rollers, performance shops, engine builders, etc? It is not because they are making any more $$$ of double's because the single's I have seen comparable to the double's prices. Just curious to why your swayed so far. That is all.
Car: 92 firebird
didnt mean to start this and yes it was a deal though more info on cam
cam lift______________- lobe ctrs
int. .298________________ int. .110
exh. .298________________ exh .118
valve lift ________________hydraulic lifters (it doesnt say roller lifters so i geuss just regular lifters. . . .idk)
int. .447
exh. .447
.050 duration ________.050 timing
int .222 ____________btc abc bbc atc
exh .222 _____________1 41 __49 -7
advanced
int .306_____________ btc abc bbc atc
exh .306______________ 40 86 88 38
thats all the info i have on it the cam lifters timing cover, chain, gaskets and oil etc
for 170
i should be shot!
for futurre members study before u post no one likes a stupid comment
int. .447
exh. .447
advanced
for 170
i should be shot!
