Stock injectors
Subscribe
Apr 13, 2011 | 12:10 AM
So does the stock computer know how to run two higher flowing injectors say 61 65 etc vs the 55 if you change heads. Also are 4 barrol tbi worth the price?
Reply 0
Apr 13, 2011 | 02:50 AM
Re: Stock injectors
Quote: So does the stock computer know how to run two higher flowing injectors say 61 65 etc vs the 55 if you change heads. Also are 4 barrol tbi worth the price?
First question, No.
Second, If I were looking to make more than 500hp w/TBI, a 4bbl unit would seem necessary, but more important is the need for more than just two injectors.
I don't think it's likely that you need, or will benefit any from a 4bbl TBI.
Reply 0
Apr 13, 2011 | 04:19 AM
Re: Stock injectors
True so is TPI the better way to go or just buy some vortecs and run a computer or carb style vortec.
I want to make atleast 250hp and right now I do not have to work for couple months.
Reply 0
Apr 14, 2011 | 04:49 AM
Re: Stock injectors
I would consider a 46mm, modded TBI for your needs.
http://www.rvmorsemachine.com/index.html
This is one of the best investments you could make.
http://www.dynamicefi.com/EBL_Flash.php
Reply 0
Subscribe
