idle
Old Apr 29, 2011 | 05:46 PM
thomasmcnulty's Avatar
Car: 91 bird, 97 gtp
Engine: lo3, 3.8sc
Transmission: 700r4, 4l60e
idle
i just bought this firebird as a project about a month ago and when i start it, it idles super low around 400 and stalls.
while i was doing the cam i cleaned all the intake passages, checked the egr and cleaned the iac.
any thoughts?
Old Apr 29, 2011 | 08:33 PM
Engine: lo3, 3.8sc
Re: idle
ok i fixed the idle but now this sob runs really rich, ugh can't win
Old Apr 30, 2011 | 01:16 PM
ex-x-fire's Avatar
Re: idle
Make sure the manifold vacuum is good, over 16" (18-21") at the map sensor. Check the coolant temp sensor & connector, do a resistance test to the cts. It changes resistance w/ temp. Check the ecm grounds & look for vacuum leaks.
Old Apr 30, 2011 | 01:22 PM
Engine: lo3, 3.8sc
Re: idle
just got learned on the esc, so let me get this right....uplug the esc, adjust timing,plug it back in and disconnect battery?
won't it just reset it?
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
