TBI vacuem lines etc.
Old May 18, 2011 | 12:32 PM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Transmission: 700R 4
Axle/Gears: stock
alright from the get go of my project of swapping out a 305 to 355 I've been around guys that are more used to Carburators, my question is can or does anybody have a diagram I can follow for the Vacuem lines that are in the front of a TBI of a 91 RS Camaro that the PCV valve is located on the front of the passenger side and the ventilation tube is located on the back side of the driver side valve cover. I've checked with a chevy dealer with my vin# for accuracy on the valves. I have figured it probably doesn't make any difference on actual location of these cause as long as there is vacuem go to the pcv valve it will automaticly circulate the air through the crankcase area. Is it a Map sensor that goes towards the back of the TBI or is it a MAF sensor and where is this located and what is a description of it that I would be looking for? I've figured the bigger vacuem in the front goes to the pcv valve, how about the other ones? Thanks
Old May 18, 2011 | 01:58 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: TBI vacuem lines etc.
Here's the diagram again. Is there a question this doesn't answer?
http://i71.photobucket.com/albums/i1...carsvacuum.gif
Old May 18, 2011 | 09:02 PM
EagleMark's Avatar
If that drawing didn't help you here is a thread with pictures of TBI units with notes to the ports.
http://www.eagle-mark.com/Forums/viewtopic.php?f=9&t=21
Old May 19, 2011 | 03:54 AM
birdman_29's Avatar
Car: 84 Z28 Camaro
Engine: Z28,305
Axle/Gears: stock
I appreciate the threat but it wont allow me to click and view it, I do not have permission to view. ?
Old May 19, 2011 | 06:31 AM
ex-x-fire's Avatar
Google "Chevy TBI Vacuum Diagrams".
Old May 19, 2011 | 06:44 AM
EagleMark's Avatar
dam it! I thought I had that bug worked out, sorry. Till I get it worked out you have to register. Sorry really don't want to force people to join when I offer help!
I will work on it
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
dutch930
Sep 11, 2015 06:58 AM
Jote4805
Aug 25, 2015 06:11 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
