350 engine swap 91 bird. Can I still use the TBI?
Old May 15, 2011 | 09:15 PM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
I have a 91 fbird w/a 305 TBI engine. The engine is getting ols so I was thinking about swapping in a 350 from a formula. Would I still be able to bolt the TBI stuff onto the 350 and achieve the same amount of power? Or would it even work at all? If it it would what changes would I need to make to get the TBI stuff to work with the 350. I didn't want to switch to TPI because of the scarcity of good parts and buying new is totally out of my budget. I was also going to swap in an LT1 cam from a vette. I'm told this is doable but would it make much of a difference? Any advice you could give would be much appreciated. Thanks
Old May 15, 2011 | 11:01 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 350 engine swap 91 bird. Can I still use the TBI?
you can do it. the tbi manifold only goes on centerbolt heads. so as long as the other engine has centerbolts its fine. you do want to change your knock sensor, est module, and PROM chip in the computer. The lt1 cam will deffinately help out the engine. It also wouldnt hurt to throw on some hooker 2055 headers.
Old May 15, 2011 | 11:22 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I'm going through the same thing now and nearing completion. I went with a crate 383 with Vortec heads and intake. Since the heads don't have an EGR passage, I had to plumb a pipe from the driver side header to the intake. Currently working on things that are in different places on the intake, lengthening and shortening wires in the harness to reach new locations, rerouteing vacuum lines. Already have EBL, so programming ECM should be simpler.
Old May 15, 2011 | 11:28 PM
macmatt's Avatar
Engine: 305 TBI
Cool. Are those headers the emissions headers? I'm trying to keep everything basically stock so I don't have to deal with the state inspectors around here. Plus I was told that I would also need to upgrade my injectors and possibly the fuel pump and regulator. As far as the est module, knock sensor and prom, what model should I get those off of? I've been looking at parts from a truck the same year. Think that'll work?
Old May 15, 2011 | 11:31 PM
thomasmcnulty's Avatar
Car: 91 bird, 97 gtp
Engine: lo3, 3.8sc
Transmission: 700r4, 4l60e
that will work
Old May 15, 2011 | 11:36 PM
luvmy64's Avatar
Your fuel pump should be fine. Get the injectors for a 454 tbi (or the whole tbi if you can get it) from ebay. I did this a few years back on an 89 RS.
Old May 15, 2011 | 11:41 PM
Al Hasse's Avatar
The Hooker 2055 headers have the A.I.R. tubes attached
http://www.summitracing.com/parts/HO...1HKR/?rtype=10
Old May 15, 2011 | 11:53 PM
macmatt's Avatar
Engine: 305 TBI
HOLY @&!%... That's expensive. However I want to do this right. I'm not looking for gobs of HP so I was looking at these http://www.jegs.com/i/Pace+Setter/766/70-1336/10002/-1
Still not cheap but a little cheaper than the hookers. Thanks for all the help guys. With everything I'm planning I hope to get around 275hp out of this engine. Think that's possible while still keeping it emissions legal?
Old May 15, 2011 | 11:57 PM
macmatt's Avatar
Engine: 305 TBI
One other thing I thought of was what kind of torque converter to get for the tranny. This is what I'm looking at http://www.jegs.com/i/B-M/130/70420/...rentProductId=
Think that's good?
Old May 16, 2011 | 12:40 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Most people dont like BM on here. they fail in a year ive read. those headers are worth every penny the hooker ones...
Old May 16, 2011 | 12:43 AM
macmatt's Avatar
Engine: 305 TBI
Ok. I'll keep that in mind. What converter would you recommend?
Old May 16, 2011 | 12:51 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
On this board they are going to recomend you to either a Vigilante. 700 bucks or so. Or Edge converters. I ran a summit brand one for a few months with no problems. its now it a buddies car. But like you said about the headers cost is a problem so that converter will have to do. I did install one of those in a van about 18 months ago and have not heard back from them about it so I guess it is okay.
Old May 19, 2011 | 12:28 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
The B&m torkmaster is a tight converter for use in trucks and vans. Get a TCI Sizzler or what TCI reccomends
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
