?'s on deleting heater core hoses
Old May 24, 2011 | 02:21 PM
cHEVy hEAVy's Avatar
Car: 1989 IROC Z
Engine: 5.0 tpi. stock [for now]
okay, ive searched on this subject but havent found the answer to my question. can i delete the hoses by running a hose from the radiator to the intake manifold? i want to clean up my engine bay and my heater core is bypassed anyway.
Old May 24, 2011 | 03:48 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: ?'s on deleting heater core hoses
Yes, you can. However, they are different sizes so you will need some sort of adapter. The cleanest way to do it is to go to the plumbing section of Lowes or Home Depot and get a brass adapter to fit the threads in the intake manifold and the hose size from the radiator. It'll have pipe threads on one side and a hose barb on the other. IIRC, its 3/4 threads and a 5/8 hose, but I could have that backwards..
Old May 24, 2011 | 11:02 PM
Car: 1989 IROC Z
thanks for the quick & detailed response! thats Exactly what i needed.
Old May 28, 2011 | 10:58 AM
skirtz's Avatar
What I did on my 91' TBI was I ran a short piece of heater hose from the back intake water outlet right over to my heater core. Then just run the other heater core hose directly to your radiator. I still have heat, my AC still blows cold, and I have no ugly coolant bypass valve in my way.
Old May 28, 2011 | 02:44 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Haha! I got rid of mine but i did it cheaply for now. just threw the bigger hose over the small one haha! dont worry, my car isnt running now but i will def fix that before i get it running. i will post a pic if u wanna see what it looks like?
Old May 28, 2011 | 03:20 PM
Car: 1989 IROC Z
well the heater core has been shot for a year or two, i dont need heat in sunny south florida anyway. as of now my heater core hoses just run to themselves. if that makes sense lol
Old May 28, 2011 | 03:22 PM
Car: 1989 IROC Z
yeah man post one up! ill be offically deleting the hoses this week some time. i cant waitt till theyre GONE lol
Old May 28, 2011 | 05:16 PM
Engine: 5.7 LSX
Here ya go. Sorry for the quality, camera phone. I zoomed in on the part that I ghetto rigged!
Attached Thumbnails ?'s on deleting heater core hoses-2011052895152.jpg   ?'s on deleting heater core hoses-201105289515.jpg
Old May 28, 2011 | 05:43 PM
Car: 1989 IROC Z
that dosent look bad for a temp. fix. have you driven it like this? im curious to know if it would hold
Old May 30, 2011 | 08:15 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
this is what i did i cut the hose from the back of the intake manifold just enough to turn it around and hook it up to the heater core. i removed the heater core bypass valve and all of its hoses. i cut the vacuum lines to it and then plugged them up. the on hose that would hook up to the hard return line i just plugged it up and everything still works fine and looks way cleaner.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
