whos good with 193 heads
Old Jun 5, 2011 | 07:32 PM
Robby12's Avatar
If you know a lot about the 193 tbi swirl port heads and setting up engines i need you to pm me thanks
Old Jun 5, 2011 | 08:33 PM
Robby12's Avatar
Re: whos good with 193 heads
?any one
Old Jun 5, 2011 | 09:01 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Ask a question
Old Jun 5, 2011 | 09:07 PM
Robby12's Avatar
i have a 1970 Chevy 350 fresh rebuild
.030 over
speed pro flat top pistons
750 Q-jet
points dizzy
268h comp cam
1.5 ratio roller tip rockers
high volume oil pump
9 quart oil pan
stock cast iron 1968 vett intake spread bore
and a good old set of 193 heads ported and polished manly swirl polished valves
110lb lt1 valve springs
.039 head gaskets
the heads are 62 cc chambers
what should i set my initial timing at i was thinking 12 degrees at idle + 22 degrees of bushing limited centrifugal timing = 34 total degrees of timing. 34 + (16 vacuum advance) = 50 degrees? would it run lol
Old Jun 5, 2011 | 10:57 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
well your not jus supposed to set up an engine's timing on what you want. You have to set it up for what it wants...your intial can be anywhere from 10-20 or more! I doubt 50 degrees advanced would be the optimal setting for it.
Old Jun 6, 2011 | 03:41 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
They are fast burn and require little timing.
Probably around 20°-23° WOT, for best power.
CR and quench/squish have an impact too.
Old Jun 6, 2011 | 02:48 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
More like 28-30* total timing at WOT, around 16-18* initial and no more than 38-42* at cruising RPM with vacuum advance.
Old Jun 7, 2011 | 11:02 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
good to know
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
anesthes
Aug 8, 2015 09:37 PM
