Please Help???
Old Jun 6, 2011 | 09:55 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
Please Help???
I have a 305 tbi trans am I've changed plugs, wires and cap and rotor and ignition coil. i am stalling out randomly with no check engine light. I pulled off the air cleaner and found no fuel being sprayed in the throttle body. Now here is where I am confused, I had an assistant crank over the engine while i pulled off the coil wire on the distributor and held it slightly close to the cap to check for spark in which at this moment the engine fired right up and fuel began to sparay. I'm guessing could this be an ignition module.
Old Jun 7, 2011 | 03:54 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: Please Help???
Check your vats https://www.thirdgen.org/vats check the wire going to dissy and ya a module goin bad could give intermitted problems
Old Jun 7, 2011 | 11:45 AM
Schurkey's Avatar
Re: Please Help???
My '88 work truck did the same thing for awhile.
Replaced the distributor mainshaft. I guess the magnets crack and/or get weak, and then there's poor signal especially at idle.
Wouldn't hurt to verify that the pickup coil is still good. I would not expect this to be the ignition module; possible but not likely.
Old Jun 8, 2011 | 08:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Please Help???
1988 car shouldn't have VATS. How long since fuel filter change?
Old Jun 8, 2011 | 09:31 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Please Help???
I think the ignition module is the #1 suspect.
Old Jun 8, 2011 | 10:51 PM
camaroinoh's Avatar
Car: 84 z28
Re: Please Help???
Umm vats came out in 88 would be the first year for it may have called it passkey though
Old Jun 9, 2011 | 12:23 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Please Help???
Test voltage to the Fuel pump relay. My car won't run somtimes and I have to "hotwire" the relay.
