Unknown Vacuum Port
Old Jun 22, 2011 | 11:09 PM
rfcomp's Avatar
Car: 1990 Camaro RS
Unknown Vacuum Port
I have a 1990 RS 305 TBI that I bought a couple of years ago. I'm trying to get it back to stock condition, all the vacuum lines were blocked off, I found a vacuum diagram and can put most of the lines back in but there is one port behind the throttlebody next to the egr that I have no idea were it goes. Could anyone tell me where it is sup[posed to be connected? I have attached a picture. Thanks..
Old Jun 23, 2011 | 12:15 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Unknown Vacuum Port
I believe that port is to supply the vacuum reservoir for the HVAC and cruise control. It runs to a check valve, then all the way to the driver side inner fender well where there is a sphere with one vacuum line attached, this is your reservoir. Immediately after the check valve, there is a tee connection which runs to the HVAC controls and cruise control vacuum diaphragm. I have no picture of it, so this is the best I can do...
Old Jun 23, 2011 | 12:19 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I just went out and looked at mine that's correct info. there. a big vacuum line feeds to the check valve then it tee's off going to the Heatering/ac system and around the drivers fender for the cruise control or charcoal canister area..
Old Jun 23, 2011 | 03:09 AM
rfcomp's Avatar
Car: 1990 Camaro RS
Thanks for the quick response now it makes sense...
db057
Jan 10, 2020 08:55 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Quzyle
Oct 15, 2015 03:35 PM
timonator
Sep 30, 2015 12:52 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
