454 injectors
Old Jun 21, 2011 | 11:36 AM
rjslape's Avatar
454 injectors
OK just started out on this got my engine together I hav a 355 with vortec heads, flat top pistons, mild cam 1.6 rockers, air gap intake, 3" oval air intake, dual exhaust with no cats. I hve seen where the 454 TBI puts out around 260 hp will the 454 TBI fit without changing fuel pump and fuel pressure regulator.
Old Jun 22, 2011 | 04:02 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 454 injectors
The 454 TB with the right injectors, should be able to handle at least twice that power if set up correctly.
The FPR is on the injector pod, pump depends on fuel demand and fuel pressure.
You will need a tune, this is the best way http://dynamicefi.com/
Old Jun 22, 2011 | 07:51 PM
rjslape's Avatar
Re: 454 injectors
Man thanks I will do some research on it. I couldnt find a price on it. By chance would any one know the price on thid and does it come with everything I need?
Old Jun 23, 2011 | 05:35 AM
thomas1976's Avatar
Car: 91 Trans am
Re: 454 injectors
http://cgi.ebay.com/ebaymotors/7-4L-...#ht_3163wt_826
Old Jun 23, 2011 | 01:59 PM
Ronny's Avatar
Re: 454 injectors
consider fuel injector connection....rebuilder
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
