tbi 350 timing need help quick.
Old Aug 20, 2011 | 12:34 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
i have tbi 350 i just got done swapping out the intake and now i need someone to help me with timing i marked the rotor but i cant tell if the distributor is sitting in the oil pump shaft correct.I tried to crank it over and it was cranking but puff came out the thorttle body.If it wasnt sitting in the oil pump shaft correct it will spin right?please help i need to get running by tonight so please help me!!
Old Aug 20, 2011 | 12:54 PM
ex-x-fire's Avatar
Re: tbi 350 timing need help quick.
If the oil pump shaft is not engaged into the distr., there would be a gap at the base.
If you are sure you have the distr. in right, then you may have to turn it slightly left or right to get it started. Then you have to check the timing w/ a timing light, don't forget to unhook the timing connector. Follow the emissions label for the loction of it.
Old Aug 20, 2011 | 01:00 PM
gmstrong's Avatar
How big will the gap be its hard for me to see if its sitting flush with the manifold.But i thought that if it wasnt sitting in there correctly that the dis its self would spin or move a tad.
Old Aug 20, 2011 | 05:33 PM
one92rs's Avatar
Car: SOLD!!!!!
sounds like you have it 180* out if it is bacfiring or puffing out of the tbi.
remove number 1 plug. turn engine over with your finger in the hole till you feel compression. bring the piston all the way up. that will be close enough to tdc. see where the rotor is facing against where number 1 is on the cap. line them up. that should get it running till you can set the timing correctly.
the base of the distributor should set flat on the intake.
Old Aug 20, 2011 | 07:15 PM
gmstrong's Avatar
I got it.Thank you!Im glad i did redid the timing because its running better then ever,the rotor itself looks like it has a good share of arcing on it probably because the timing was alittle off before i touched it.But what a nightmare of a job i got into the heater core hose snapped off inside the intake manifold and had to rig up a hose for that.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
xkingcodex
Feb 12, 2020 07:43 PM
lakeffect2
Aug 23, 2015 08:44 AM
