fuel pressure suggestions plz
Old Sep 15, 2011 | 02:10 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I have rebuild my camaro again and did quite a bit more engine mods than previous and need some recomendations on what PSI to run the fuel pressure at. Ill give you as much info on the motor that I can remember..
305 bored 30 over with flat top pistons.
081 heads with mild port and polish and gasket matched
comp cams 1.52 ratio RR with matching pushrods
Cam
Duration at 050 inch Lift
206 int./212 exh.
Advertised Duration
258 int./264 exh.
Valve Lift with Factory Rocker Arm Ratio
0.480 int./0.488 exh.
Lobe Separation (degrees)
112
Weiand 7525 intake manifold with EGR blocked off and TBI adaptor plate
ultimate TBI mods
open element
2055 hooker headers, no cat and full 3" catback
timing is up around 10 or 12 degrees base timing
Acel shorty header plugs
acel cap and rotor with 8.8mm wires
TPI fuel pump
stock tbi injectors
93 octane fuel
Im running the fuel pressure around 14psi. I have the adjustable regulator and several springs to get it just right. I will be getting the EBL soon but in the mean time i need some help from people with similar setups. thanks
Old Sep 15, 2011 | 02:41 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: fuel pressure suggestions plz
Gotta watch your BLM's or o2 swing to pressure tune.
Old Sep 15, 2011 | 06:35 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
the egr needs to be disabled in the computer also does it not?
Old Sep 15, 2011 | 06:57 PM
one92rs's Avatar
Car: SOLD!!!!!
yes the egr does need to be deleted. your prolly going to need 350 injectors. call or email brian at tbi chips and talk to him. he can burn a good chip to get you going. he has done plenty of swapd such as this to.
Old Sep 15, 2011 | 07:01 PM
iggy1991's Avatar
I also have a chip installed from TBIchips from a good 5 years ago. The egr will be disabled when I start tuning. It just doesnt fit unless I use the TB spacer and then the TBI wont fit under the hood! What are other people running their FP at?
Old Sep 15, 2011 | 07:52 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
im somehwere betwen 10-20 lol. im having issues.
Old Sep 16, 2011 | 09:30 PM
iggy1991's Avatar
come on.... wheres all the hardcore TBIers that have been playing with this injection method for years now?
my previous car ran 14.8 at its fastest and didnt have any of the engine work, all bolt ons. I had that one set at 12 or 13psi.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
