Fuel pump questions
Old Sep 23, 2011 | 05:34 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Fuel pump questions
So my car has been running rough the past few days. I suspect its the fuel pump. Had my mechanic friend put a gauge on it to check and see. My questions are:
1. The gauge read 10 psi. What is the factory stock reading on an L03? I searched but found nothing.
2. What are some recommendations for a replacement? AC Delco, Delphi, Airtex, Walbro?
3. My fuel gauge doesn't work either. Quit after the last time I had the fuel pump replaced. What all do I need to get it working again? Just a new float or is there more to it?
Thanks for any help, Chris
Old Sep 23, 2011 | 06:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel pump questions
I'd do Walbro or Delco, skip the cheap stuff.
TBI car should read 12psi.
Have you changed the filter in the last year? Might solve the issue.
Usually, fuel pumps work or they don't - so if it's working, I'd look elsewhere before droppin the tank again.
Old Sep 25, 2011 | 12:06 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I just bought a new fuel filter but haven't installed it yet. Might try that first. I had another pump go bad a few year ago, but it didn't die right away. In fact I drove it for a few weeks before replacing it. The car just ran really bad while I drove it. It has the same feel and symptoms now as it did before. It idles ok in neutral but dies when you put it in gear. I have to hit the gas to keep it running. It has little to no power when driving and runs real rough.
I hate to have to drop the tank to replace it if its not bad, but I think with the low reading on the gauge and the similar symptons as before it leads me to believe the pump is starting to give out.
In fact the car has been run out of gas several times in the past five years due to the broken gauge, maybe 8-10 times in the past four to five years. And it often runs at a half tank or less. I know the pumps need a ceratain level to keep them cool and don't like to run low.
Old Sep 25, 2011 | 12:35 PM
one92rs's Avatar
Car: SOLD!!!!!
i have a tbi car and this is the pump i used. it is for the tpi cars but works great with the tbi.
Old Sep 25, 2011 | 12:52 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
What is it? I don't see anyting?
Old Sep 25, 2011 | 05:23 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
DELCO EP241
Or walbro 190lph pump
do not run the 255lph
But also dont change your pump til your sure it is. 10 psi is iwthin specs. 9-13 psi for stock setups.
Old Sep 25, 2011 | 05:44 PM
one92rs's Avatar
Car: SOLD!!!!!
sorry about that.
http://cgi.ebay.com/ebaymotors/NEW-A...item23128e73ab
Old Sep 26, 2011 | 12:19 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I checked the pressure at the fuel filter. It only read 10 psi. I think it should be more. I also just replaced the filter to see if that helped and there was no change. Looks like its time for a new pump.
Old Sep 26, 2011 | 06:52 PM
one92rs's Avatar
Car: SOLD!!!!!
ten psi at the filter seems a lil low. but! if you checked the pressure with the regulator still hooked up then i could be a problem also. do this. get a pair of pliers and squeeze the fuel return line under the hood with a gauge on it and see if the pressure rises.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
