another fuel pump question
Old Sep 25, 2011 | 06:24 PM
t-roy383's Avatar
i have a 91 rs. when i check the fuel pump pressure it reads 9-10 lbs. when i check the actual fuel pressure it reads 10-11 lbs, would it be a bad pump or regulator?
Old Sep 25, 2011 | 07:16 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: another fuel pump question
where exactly are you taking the pressures.
Old Sep 25, 2011 | 07:28 PM
t-roy383's Avatar
the inlet line by the alternator
Old Sep 25, 2011 | 07:34 PM
t-roy383's Avatar
i removed the rubber hose from the fuel line and connected an inline gauge
Old Sep 25, 2011 | 08:36 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
seems a bit low. A TBI rebuild kit isnt expensive and could be the cause.
Old Sep 26, 2011 | 07:16 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Is this tread about the same issue you posted about in the previous tread? https://www.thirdgen.org/forums/tbi/...-way-rich.html
Stock fuel pressure is around 10-13 psi on these cars and the fuel pump should push at least 15 psi.
If the fuel pump only produces around 9-10 psi, as you described, it is time to replace it.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
