running way rich
Old Sep 16, 2011 | 08:40 PM
t-roy383's Avatar
running way rich
posted b4 bout a 305 to 383 swap, 383 has a dead spot which is prob low fuel pressure, but im running way to rich. any suggestions on how to stop it from running rich?
Old Sep 17, 2011 | 01:51 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: running way rich
You need tuning. That setup is completely different than what you originally had. See the stickies and search DIY-Prom board for more info.
Really the problem is that the calibration in the ECM doesnt match what the motor requires, which is why it has rich and lean spots.
Old Sep 17, 2011 | 07:30 AM
t-roy383's Avatar
i had a chip made for this set up
Old Sep 17, 2011 | 04:22 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Made me courious, what injectors @ what pressure have you set to match your coustom chip for the 383?
Old Sep 17, 2011 | 06:35 PM
t-roy383's Avatar
stock 350 injectors, stock fuel pressure. it is a 383 with 305 h.o. heads, stock intake, dist. and componants
Old Sep 19, 2011 | 05:16 AM
thomas1976's Avatar
Car: 91 Trans am
TBI or TPI?
I thought the 305 valves are to small for a mild 383ci and that the stock 305 heads flow really bad. https://www.thirdgen.org/forums/tbi/...-headflow.html
Old Sep 20, 2011 | 06:29 PM
t-roy383's Avatar
im goin to change heads to lower my compression
Old Sep 24, 2011 | 03:25 PM
t-roy383's Avatar
what is a good way to test fuel pump, regulator,and fuel pressure?
Old Sep 25, 2011 | 05:04 AM
thomas1976's Avatar
Car: 91 Trans am
It would be easiest on the feed line right next to the alternator.
Sometimes it is good to monitor FP under load too.
With this one you can fix the gauge under the windshield wiper for some accurate testing http://www.actron.com/product_detail.php?pid=16175
Some good information https://www.thirdgen.org/forums/tbi/...sure-test.html
https://www.thirdgen.org/forums/tbi/...-pressure.html
Old Sep 27, 2011 | 05:48 PM
t-roy383's Avatar
got the fuel pressure up to 14lbs, did a complete tune up but still running rich and still have a dead spot. any ideas? and what controls the spray pattern of the injectors?
Old Sep 28, 2011 | 03:54 AM
thomas1976's Avatar
Car: 91 Trans am
The VE tables are probably the cause, also 14 psi on the stock tune may be on the rich side, if you have the tuning equipment or the EBL flash upgrade this can be adjusted.
Old Sep 28, 2011 | 06:51 AM
ex-x-fire's Avatar
Measure the engine vacuum at different ports, it should be 17.5" or higher. If its less it'll cause the map sensor to richen it up.
Old Sep 28, 2011 | 02:13 PM
Ronny's Avatar
Consider a datalog of sensor readings. Need a ALDL cable and winALDL(free program) and a laptop. A datalog will tell you what needs to be changed.
Fuel pump needs to provide adequate fuel at WOT. Stock FP?
Your chip may not be quite right for your app.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
