anyone running l31 heads on 350 tbi
Old Oct 4, 2011 | 11:01 AM
  #51
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: anyone running l31 heads on 350 tbi
i was going to change and make l05 into a roller due to flat tap is not that good in the long run if you drive often it wears out quicker due to more friction
Originally Posted by bluers91
I agree alvan. I have noticed big differences while creating cam files measured @.050 vs Advertised duration. DD2000 also favors some Roller cams from what I have seen.
To make the intended power range it will require better valve springs and some work to the heads for a little increased lift. You may consider some flat tappet cams since you have the L05.
Old Oct 4, 2011 | 11:03 AM
  #52
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Originally Posted by alvanwie
bluers91,
What did you use for the intake centerline for the LT4 cam?
I just used a cam file I had already sitting around. It appears to be 110. Not sure if that is correct or not.
Old Oct 5, 2011 | 05:57 PM
  #53
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
In case you have not came across this tread https://www.thirdgen.org/forums/tbi/...i-buildup.html it has good information, including max lift with the vortec heads.
I would also suggest to play with camquest6 http://www.camquest.com/, skip the flat tapped cams.
This is the first to do list before buying anything
edit: add this to the list http://www.kb-silvolite.com/calc.php?action=comp since you are looking for pistons and head gaskets.
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
