305 tbi help!?
Old Nov 17, 2011 | 07:02 PM
Scott92Camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 305 tbi
Axle/Gears: 273
305 tbi help!?
i have a 92 camaro with a 305 tbi and i was wondering does the 305 tbi have the roller cam tray to hold the lifters!? other words can i put a roller cam in the block!?
Old Nov 17, 2011 | 08:52 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: 305 tbi help!?
Im pretty positive your block is a roller and already has a hydraulic roller cam in it. I'm assuming you meant the bosses andbthe dog bones and all that jazz?
Old Nov 26, 2011 | 10:25 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 305 tbi help!?
Starting 1987 model year GM equipped all passenger car SBC V8 (305/350) with roller cams. Trucks were not so fortunate and continued to use flat tappet lifters until introduction of Vortec (L30/L31) in 1996 model year trucks. An SBC block (305/350 car or truck) cast after 1986 is more than likely have all provisions for roller cam - i.e. lifter valley spider retention bosses. There was a short transition period between 1985 to 1986 when SP RMS SBC blocks did not had had aforementioned provisions for a roller cam.
To be certain locate block casting number behind the china wall or pull intake manifold. RPO stamping can also additional clues provided that PO did not swap cams.
//RF
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
