Crossfire -> TBI swap
Sooo like some of you know iv been talking about putting a TBI on the vette simply because it flows better overall then the crossfire. I know the TBI isn't the most effective platform but i choose it over the TPI because i HATE the TPI runners.
Atlest with a small cam i plan to be shifting at around 6000 with the TBI before running out of air. Found a intake for $20 and the throttlebody for $30.. polished up the runners a bit and me and Alex bolted it on.
I used the adjustable fuel pressure regulator from the crossfire and the injectors since i didnt know if the TBI came from a 305 or a 350
It runs about the same right now but its smoother. It only has a few degrees of timing when we took it out and the computer is still learning. Im happy though, heres some pics.
Re: Crossfire -> TBI swap
i already had a TPI fuel pump in the car, The wiring harness was all plug and play except for the TPS, we simply cut a pig tail off a extra harness we have and rewired it.
Stock crossfire ECU is still running it too haha.
That's the cheapest swap I've heard of. The stock tbi intake is a marginal performer, I'd try to find a edelbrock or a holley at some point. I'm sure if you adjust the timing & fuel pressure alttle you'll be getting it to run real good. Good job!
Plan to go do some tuning later today see if i can't get it pulling harder.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
how much for your crossfire parts ?
Added some fuel pressure, set the timing too about 6 or 7 advance plugged the EST back in and went for a drive.
So much better, huge improvement over the crossfire the entire powerband is smoother and cleaner and pulls great.
Only problem is my tach is flipping out right now, won't stay steady.. might need to ground this odd resistor that the crossfire had.. not sure
whats correct spec? i could check and see what its currently reading. It might have to do with the hesitation im having down low right now. Figured i need to keep driving her and let the ECU learn a bit more.
Car: 1988 Pontiac TransAm GTA
Transmission: 5speed manual
Axle/Gears: 3:42 gears
alright i know its a random question but can you help me, im still new to this site and i want to know how to post new threads on the messages boards
added more fuel pressure still doing it.. im having a high idle problem, once the car is all the way warmed up it idles at 1400 rpms. other then that and the slight hesitation down low untill i give it more throttle it runs perfect.
I think mine had a idling problem too, this is what I did, the ecm likes to see that it can close both iac valves, but you only have one hooked up, I found a iac & housing off of an 85 camaro 2.8L mpfi. I cut down the excess material on the housing. Now the ecm can fully operate both iacs even though only 1 is metering air.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
If you witness that only fix besides swapping ECU's is to plug IAC port(extend pindle) and use throttle stop. You would lose fast idle on cold start.
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
if ur selling parts off the cfi icould use the throttle cable bracket.
Its too bad you can adjust the tps on the high side of the specs. Remember the tps does what a carbs. acceration pump does. I guess i'd bump up the pressure alittle more.
Are you running an open element air cleaner? Is the outside air cold? Your ecm does not mearsure the air temp like some of the later tbi systems. The original crossfire had the thermac system to help fight cold weather hesitation.
its been chill air for Texas, I havn't put a air filter on it yet haha.
See DCS site. they offer a HAM board that allow use of stock CF harness. It will need to be soldered in the ECU by you or a techncian. 1228746 allows IAT control. Others do as well. Many will use the later model PCM. 7427. I believe it was used on 1995 TBI trucks.
EBL live would be the same price as that HAM board, a burner, cable, chips and the ECU.. sooooo EBL or megasquirt it is..
Heres a video showing what the car does you can see how it hesitates between the throttle opening start of the video not so bad, middle its pretty bad..
http://www.youtube.com/watch?v=UgjbO-sz_nE
Having a TPS issue havnt checked the code for it yet though, and my stupid CTS is broken but my buddy took a video of me running through first.. Not the best of video and the cars not running optimal but figured id share..
http://www.youtube.com/watch?v=XfisT...el_video_title
Car: Corvette
Engine: 5.7
At least yours runs. I did this swap on mine and it has been a nightmare from day 1 haha. Nothing fit right so I kept having to mod crap. What are you running for an air cleaner?
what problems are you having? this was really easy.. maybe i can give you some pointers, Any open element air filter will work but honestly i have no money and can't afford to put one on there yet.
Car: Corvette
Engine: 5.7
Well I had a 2101 manifold and I used that with an adapter and it kinda threw the placement of **** off so I had to mount the coil on the side like on a tpi car ( i also swapped to a small cap dist.) The manifold had a rib in between the two rear bolts so I had to notch the coil bracket. Then there was some other small problems because somebody hacked the car prior to me owning it. How did you reuse the stock detent cable(if auto)? Mine was way too short originally. The car runs fine etc but I keep having to change the way certain things mount so it isnt exactly "safe" to drive it as is.
I had a problem w/ the tv (detent?) cable, theres a bellhousing bolt that had a bracket or something on, it was holding down the cable. I reused my oem cable.
I used an open element air filter, at 2x14", flat type base.
Car: Corvette
Engine: 5.7
What brand did you use? I got some sort of air cleaner here but the hood wont close with it and I don't wanna buy another that wont fit.
Its a K&N, the top part is maybe a 1/4" above the injectors. I didn't use a wing nut, I moded the hold down stud, I welded a a long nut to it, so I could use a screw to hold it down. I had to trim the filter enough to clear, then laid a thick bead of rtv & glued the filter to the lid. The filter was originally a 14X2 1/4" element.
Car: Corvette
Engine: 5.7
So the car has been running fairly good since the TPS fixed and CTS fix.. How ever its starting to backfire on the occasion so I know the tune is adjusting but maybe a bit too lean.. What can I do??
Backfiring is mosy likely during AE/throttle movement. Enrichen the AE. I would do both TPS AE and MAP AE. Do incrementally 61 units at a time. If no response try 122.
Car: Corvette
Engine: 5.7
I looked at some of the carb hats but they are too much $ new. Maybe if I found a deal on a used one. Eventually I am gonna swap motors and go to mpfi so I dont wanna dump full retail money into this setup
Car: Corvette
Engine: 5.7
I am probably going to pick up the 1480 mr gasket air cleaner that the parts stores sell. its only 20 bucks and from what I keep hearing it should fit.
[/IMG]
