need some opinions
Old Nov 29, 2011 | 11:12 AM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
need some opinions
I know I'm gonna probably get mixed answers but I'm starting my planning/saving for my 383 swap and I would like some opinions on the intake setup, should I keep and soup up the tbi or swap over to some other intake? I dont plan on going all out race car, just mild street/strip
Old Nov 29, 2011 | 11:28 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: need some opinions
I plan on getting a blueprint engines 383 crate next year and im plannin on goin carb to start off
Old Nov 29, 2011 | 12:09 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Well this is my first car with fuel injection so i want to try and keep it fuel injected. I was looking at the blueprint 383 with the tbi intake on it already, but I didnt know if i should keep it tbi or not
Old Nov 29, 2011 | 12:14 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
If you are building a 383... The TBI intake would need max porting. And still lack flow
If I were you I would purchase a performance intake like a weiand stealth.
And look at patriot heads or similar..drop 50#'s and have a respectful ride
Old Nov 29, 2011 | 12:53 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
I was told that intake setup wouldn't clear the hood
Old Nov 29, 2011 | 02:24 PM
88gta3508's Avatar
Engine: 231 / 383
I'm long out of the carb setups... I thought with a low profile cleaner the setup will clear
Old Nov 29, 2011 | 03:03 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
I dont personally know if it will clear or not thats just what I was told
Old Nov 29, 2011 | 06:04 PM
ex-x-fire's Avatar
Have your 383 built for strong low/midrange torque, get an edelbrock performer rpm intake & adaptor, I'd look into getting some vortec heads as they have good budget/performance ratio. It'll be easier to get it to run good if you use a mild cam. I'd get a complete 350 vortec engine from the junk yard, use that to build your engine. It'll come w/ the good heads & roller cam.
Old Nov 29, 2011 | 06:17 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Does everything match up pretty good with the carb'd intake (sensors etc)
Old Nov 29, 2011 | 07:37 PM
ex-x-fire's Avatar
Sure, read the stickies.
Old Nov 29, 2011 | 07:51 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Ahh good point, so is there any specific tb yall would recommend? Or should I just use a 350 or 454?
Old Nov 29, 2011 | 10:37 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Stick with the TB you have (do the common mods), find a carb manifold you like & use a quality adapter to mount the TB.
The biggest mistake, & first sign of induction ignorance, is the use of a larger than necessary device. If you are going to run your 383 over 7k rpm I suggest a 46mm TB from these guys,
http://www.rvmorsemachine.com/index.html
Edit: It would be smart if you first make your ECM tunable & learn to tune on your existing engine.
http://www.dynamicefi.com/EBL_Flash.php
Old Nov 29, 2011 | 10:44 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Ok I didn't know if I could use my stock tb, that makes me feel better
Old Dec 12, 2011 | 03:13 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
On the carb'd intakes does it matter if its single or dual plane with the tb?
Old Dec 12, 2011 | 06:15 PM
ex-x-fire's Avatar
If its a 383, I'd go w/ a dual plane with the center cut down alittle. Or add a carb spacer if theres room.
Old Dec 12, 2011 | 06:25 PM
bigreed91's Avatar
Car: 1990 camaro rs
I was readin the other day that for a carb on a dual plane you wana go a lil bit bigger in the cfm as compared to what you'd use on a single plane. I assume it would be the same for tbi
Old Dec 12, 2011 | 07:56 PM
xch3no2's Avatar
Transmission: TH400
That information is incorrect, savvy guys know that a dual plane only hides the gross ignorance of over-doing the fuel metering device better.
Old Dec 12, 2011 | 08:03 PM
xch3no2's Avatar
Transmission: TH400
If your going to use a single plane there is only one I'd suggest,
http://www.summitracing.com/parts/EDL-2901/
Old Dec 12, 2011 | 09:09 PM
bigreed91's Avatar
Car: 1990 camaro rs
thanks for clearin that up for me, i dont mean to put out wrong information
Old Dec 13, 2011 | 04:48 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Haha thats the intake I was looking at, which drew up my question
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
