350 Knock Sensor.
Old Dec 11, 2011 | 01:01 PM
RSCAMAROGUY91's Avatar
Car: 1991 RS Camaro w/ Factory T-Tops
Engine: Built 355 ci SBC w/ Carb
Transmission: Borg Warner T-5
Axle/Gears: 4.10 with Posi-Trac
350 Knock Sensor.
After the recent engine swap in my '91 RS to 355 Small Block, I know need to update the Knock Sensor. I went and checked at my local parts store, and discovered that in '91 the Knock Sensors are different depending on if you have an automatic or manual transmission in the truck lines. The Z/28 uses the same knock sensor as the automatic truck I guess because there wasn't a manual transmission in the 350 powered Z/28's back then. SO, my question is which Knock Sensor should I get? I figure I'll need the one for a manual truck since my car is a manual transmission car. BY THE WAY, I read the 305 to 350 swap Sticky and didn't get an exact answer from it on which one to use.
Old Dec 11, 2011 | 09:10 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 350 Knock Sensor.
KS + ESC selection depends if your 350 is equipped with a roller or flat tappet cam. For a flat tappet cam 350 I would use 84-86 Corvette specified parts:
ESC module - GM 16126761 (AC-Delco 216-45) (Old part 16052401)
Knock Sensor - GM 10456287 (AC-Delco 213-325)
For roller cam based 350 I use knock sensor from 92 B-car
ESC module - GM 16052401, 16128261, AC-Delco 216-47
Knock Sensor - GM 10456288 (10456126) AC-Delco 213-324
Please note that GM obsoletes and supersedes part numbers left and right. The after market parts - SMP, Airtex, Wells, etc tend to be generic approximations of original part. Most of the time they work OK, but depending on a particular combination they may not be an optimum combination.
//RF
Old Dec 12, 2011 | 07:06 PM
Alright that sounds good. I've got a flat tappet cam in mine, so I'll be goin' with the '84-'86 'Vette stuff. I'm still wondering why there would be two different sensors for manual and automatic transmission car.
Old May 20, 2012 | 05:22 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Those numbers are they for an auto or manual or does it really matter? I found them at Amazon for 81 for the pair
Old May 22, 2012 | 12:23 AM
RFmaster's Avatar
Car: 75 Beast
Should not make the difference - at least parts cats do not show.
Old Jun 3, 2012 | 01:11 PM
gregl316's Avatar
They arrived from amazon and there both A/C Delco and shipping was free.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
angel2794
Sep 8, 2015 06:22 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
