blown headgasket/bad intake gasket? opinions needed.
It appeared my headgasket blew on my 91 305 camaro(rough idle sweet smelling exhaust/white smoke bubbles in radiator) well I tore the top end of the engine down. Checked both headgaskets and it appeared both were fine didn't see anything wrong with it but the heads did have a black oily water on the exaust valves of the heads any ideas what the problem was? I'm getting my uncle who owns a machine shop to check it out and also possibly do some work to the heads and intake while there off. (the engine that's in it is a jasper 305.) Also anyone know if it would be worth it to mess with the stock heads and intake what kinda gains is expect? I was also going to deleat the egr since I live in a non emission state.
Re: blown headgasket/bad intake gasket? opinions needed.
you can only port the swirlies so much but to take advantage you need to change your lift and duration (camshaft) and that means a new tune (not an easy proposition)
the OP might not have the cash to rebuild an engine from the junk yard. Surely you are not suggesting to just toss in an unknown junk engine into a car?
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
