Carb intake- tbi injection adapter questions
Old Dec 22, 2011 | 06:12 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I have an edelbrock performer rpm carb style intake, what's the best adapter to use on it for my tbi? It is a dual plane
Old Dec 22, 2011 | 07:17 PM
ex-x-fire's Avatar
Re: Carb intake- tbi injection adapter questions
Their all pretty much the same, a 3/8 piece of flat steel w/ 2 big holes, 7 smaller holes. You can make one too. Use a tbi gasket as a template.
Old Dec 22, 2011 | 07:39 PM
one92rs's Avatar
Car: SOLD!!!!!
trans dapt makes them. around 40.00
Old Dec 22, 2011 | 07:49 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
I was wondering if one could be made... That's awesome. Does it have to be steel? Could you use aluminum? It doesn't have to have any special bevels or anything?
Old Dec 22, 2011 | 08:00 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
And what's the max height before it hurts your performance? Would 1" thick be too much?
Old Dec 22, 2011 | 08:21 PM
ex-x-fire's Avatar
You can use aluiminum, 1" thick is fine as long as you can close the hood.
I'd start by having you intake & tbi gasket handy, take a piece of cardboard & outline the carbs mounting flange, then take the tbi gasket & center it over the 4bbl. hole. Make marks where the tbi holes are, this will help you make the real one out of steel or aluiminum.
When its done bolt the adaptor to the tbi, open the throttle & look for any mismatches that might have to be clearenced. Make sure the mounting hardware is flush so it wont interfere w/ the intake. You dont need to bevel it, but it might be beneficial to open the center between the bores.
If the tbi bores overlap the intake, I'd try to grind it smooth, just don't go to far.
Attached Thumbnails Carb intake- tbi injection adapter questions-bpk0vmwcgk-kgrhqih-eqeu-ihulmblr8
Old Dec 22, 2011 | 08:27 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Making one oval vs two individual holes is what your meaning? Cool, good deal. I'll get started. The hood will be an issue right now, due to the fact I don't have my cowl hood yet, but that's due to the fact I haven't decided on ss/cowl yet. I want the pro touring hood, but it's pricey, thanks for the info
Old Dec 22, 2011 | 08:29 PM
ex-x-fire's Avatar
Yeah, its fun to make your own parts.
Old Dec 22, 2011 | 08:39 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
You make that one? That's awesome!! What are the 3 little holes for around the tbi chambers?
Old Dec 23, 2011 | 06:11 AM
ex-x-fire's Avatar
No, I didn't make that one, its just an example of an open center version.
The 3 holes are the tbi bolt pattern.
Old Dec 30, 2011 | 01:55 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Got another question, was going to start making my adapter, marking out my template.... When I put the tbi on the intake, the tbi barrels do not set inside the carb bores, what's the trick to doing this? I don't want the lip of the intake to collect fuel, or would this not be an issue? Just curious!!
Old Dec 30, 2011 | 02:02 PM
cphgncowboy's Avatar
Car: 1991 Formula
part number 2211 from summit 43 bucks
Old Dec 30, 2011 | 04:32 PM
VORTECCADDY's Avatar
Engine: 383 Superchared
Transmission: 700r4 built
I have the TransDept one. $20.00 shipped.
Old Dec 30, 2011 | 04:49 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Pm sent
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
