tbi injector pulse
Old Dec 27, 2011 | 05:43 PM
t-roy383's Avatar
tbi injector pulse
what makes the tbi injectors pulse? i have a steady spray at idle instead of a pulsing spray. it runs rich at idle. has new tune up, including distributer.
Old Dec 27, 2011 | 06:44 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: tbi injector pulse
the ecm pulses the injectors via a ground signal. hook up a timing light and point it at the injectors while it is idling. it will look like a steady stream to the naked eye. is it throwing any codes?? are the injectors dripping at all. and replace the tbi gasket. when you do that turn the tbi over and clean the gunk out from underneath it.
Old Dec 27, 2011 | 06:47 PM
ex-x-fire's Avatar
Make sure your ignition timing is set right, if its retarded, the engine vacuum will be low causing the map sensor to tell the ecm to richen it up.
Old Dec 28, 2011 | 12:41 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
or a bad CTS (or disconnected CTS) will cause rich idle.
Old Dec 28, 2011 | 05:55 AM
ex-x-fire's Avatar
If the cts is unhooked it'll run rich all the time, the ecm will think the coolant is -40*.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
