tbi questions
Old Apr 14, 2012 | 12:09 AM
  #151
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: tbi questions
The oil pressure sending unit (the chinese specials from the auto parts store) are known to go bad right from the start. My 89 TBI car did not read right until the 2nd new sender in two days was installed from Auto Zone.
That sucks but that's how it is. You just keep trying until you get a good one. Do you have three wires in your plug going to it? The two fat ones are for the fuel pump and the small one is for the gauge. You should be able to ground the skinny one to make the gauge work on the dash while someone else is watching. That will tell you if the gauge is working. If you have four wires in the plug, then the two fat ones are still for the fuel pump and the two skinny ones are for the gauge. Don't ground the skinny ones out but hook them together and they should make the gauge run.
I can't remember how many pins are in it but I was thinking mine was three.
Old Apr 15, 2012 | 07:36 PM
  #152
andrew91fbird50's Avatar
Car: 89 Formula
Axle/Gears: 10 bolt 2.73
Re: tbi questions
i will replace the temp sensor. i really hope that is the problem it seams like when its in closed loop its running the best and strongest until it hits 240* and starts getting pissed at me for not replacing the fan switch. getting things back to stock performance is hard when everyone before you screws everything up
Old Apr 16, 2012 | 04:09 PM
  #153
Car: 89 Formula
Re: tbi questions
i have the three wire pin. its so frustrating because i almost have the car complete. i finished installing the exhaust set up today. it sounded very good with the flowtech raptor muffler. definitely well worth the 24$ i paid for them.
im going to order a new gauge sending unit and hopefully that will work. im tired of stairing at 0 oil pressure all the time.
what wire is the right one for the cooling fan? i have a few different green wires that are just cut and are now laying to the side of the engine bay and i cant figure out which one is it. theres atleast 2 green wires that im sure do two completely different things
Old Apr 17, 2012 | 05:20 AM
  #154
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: tbi questions
Not sure about green wires at this point, but I do have a schematic for an 88 Firebird TBI which ought to be pretty close.
At any rate, with your hacked wiring and all, if you make your fan circuit look like the schematic it is guaranteed to work, even if its not 1991 spec.
You may need to buy a new coolant max temp switch if the 1991 engine does not have it.
Attached Thumbnails tbi questions-vin-e-cooling-fan
Old Apr 17, 2012 | 05:26 AM
  #155
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: tbi questions
My internet is not the best over here, so as picture quality goes you will most likely need to download the picture to your PC first, then use your picture viewer to enlarge or enhance the picture as necessary.
Good luck!
Old Apr 20, 2012 | 04:55 PM
  #156
Car: 89 Formula
Re: tbi questions
well. i bought the rad fan switch and a connector. installed both and connected the wire to the green/white wire nothing. no fans once it gets to 250*. fans work. i ran a hot straight to battery. work great. so what i did was i ran a switch into the car with the inline 30 amp fuse and a matching switch. connected to the battery and works like a charm.
on a brighter note. im now getting all of the parts together for a carb 350 swap.
Old Apr 20, 2012 | 06:45 PM
  #157
Car: 89 Formula
Re: tbi questions
after a long bath.
sorta clean engine bay
left side stock fbody servo right side vette servo
my kyb gr2s
Old Apr 21, 2012 | 09:43 PM
  #158
bucanero's Avatar
Car: 92 Camaro RS, 25th Anniversary
Engine: 305 cid, 5.0L V8, TBI
Transmission: 700R4, 4 Spd Automatic Transmission
Re: tbi questions
I'm planning to upgrade my 305 TBI engine replacing key parts for better performance that is badly needed for my 92 Camaro RS. I just made a list of parts needed and the most significant parts are the Heddman Headers with a complete Borla exhaust while the engine will have the pulleys replaced with March machinery aluminum and a spacer on the TBI while I have the K&N air intake assembly. I'm thinking about replacing the cylinder Heads with aluminum heads with 1.5 rocker arms making them taller. What brands and parts do you recommend?
Old Apr 21, 2012 | 10:48 PM
  #159
Car: 89 Formula
Re: tbi questions
If your gonna put all that into it then you might as well swap the block for a 350 or something bigger.
Operation 355 is in full effect i got my 750 carb today. Ill be posting pictures of my 1970 chevelle race car.
Old Apr 21, 2012 | 11:09 PM
  #160
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: tbi questions
Why are you ditching your TBI now? Do you not want to learn to tune it? Or do you just like carbs better?
Just curious. Glad to see things progressing. Its starting to look like a daily driver!
Keep up the good work.
Old Apr 21, 2012 | 11:18 PM
  #161
Car: 89 Formula
Re: tbi questions
It seems like a lot of frustration to get a poor stock fuel injection system to work properly without restriction. Especially with a 355 coming soon i dont feel like messing around with the tuning and finding everything to make it run. I have a holley dual feed double pumper 750 off my cousins cutlass.
Just put a new distributor in the chevelle. Runs like a monster heres a video http://www.youtube.com/watch?v=Q3prf...PYSNWDtz-otsE=
Old Apr 22, 2012 | 12:21 AM
  #162
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: tbi questions
You can say its a lot of work, because it will be, but its not a poor fuel injection system. There is the ongoing debate over "wet flow" intake systems versus port injection, and TBI shares those characteristics with the carburetor.
There are TBI guys here who make big power, but it can be a pain to learn all the secrets of the trade. In the long run though, I like ECM controlled fuel injection better because its easier to get the dual personalities of good highway economy for long trips and killer power on the street. My carb experiences allow me an "either-or" type of situation, with my closest compromise being the Quadrajet.
But I'm a budget guy too, and I'm all for the "use what ya got" philosophy.
Good luck and I'll be watching to see how it turns out.
Old Apr 22, 2012 | 08:12 PM
  #163
Car: 89 Formula
Re: tbi questions
i didnt mean to say poor fuel injection system. i mean its great for a daily driver but if i were to tune and build on fuel injection id either go tuned port with the fast management system or like a holley efi type of thing. which are both COMPLETELY out of my budget. im working with part time hours here.
but i certainly will post back here what i happen to get the best benefit out of. ill probably stay tbi until i finish the other engine
Old Apr 22, 2012 | 10:57 PM
  #164
KrisW's Avatar
Engine: 2.8/TBI/TPI
Re: tbi questions
Well, I suggest doing a lot more research on TBI before throwing it overboard.
I used to say the same things you are saying, but then I spent weeks on this site in the TBI sections, reading everything about getting them to run well, making them perform, and I could not believe all the stuff in here.
It seems that tuning is the key. ECM tuning I mean, after the mechanicals are all worked out. It doesn't cost much to get the software and the few hardware tools necessary to burn chips and the rest is just experience. In a setup like you have, this is the best way to do things. Like me, you have much more time than money ahhahahha. That's your advantage!
Anyway, I am encouraging you to start burning chips for your car with an old laptop and to not give up. It will cost you money for new fuel lines and all the other stuff to make the car carbureted anyway, so money is going to spent.
Good luck!
Old Apr 23, 2012 | 07:26 AM
  #165
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: tbi questions
If this refers to anything under 500fwhp, then that statement is just
Check out EBL flash, you will realize, yourself.
How much hp does your 355 make?
Old Apr 23, 2012 | 08:38 AM
  #166
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: tbi questions
even if it makes more than 500 hp you can run two tbi's with a ebl flash ...
i too suggest checking into the ebl flash an staying tbi .
Old Apr 23, 2012 | 01:54 PM
  #167
thomas1976's Avatar
Car: 91 Trans am
Re: tbi questions
True, though two TBI TB's is not an easy task, by that time I would personally go with port injection and EBL flash, if 1st gen SB has to be.
Im still courious about his 355 build.
Old Apr 24, 2012 | 03:25 PM
  #168
Car: 89 Formula
Re: tbi questions
355 build has been scrapped. i got prices for everything and it is FAAAAAAAAR beyond my budget. i was at around 710 and that didnt include head work or machine work. that was just the price for cam rebuild kit with pistons and rods. not to mention another 100 for the price of the block and crank.
i will run my 305 until it dies. i have been busy doing a lot of body inspection on the car. the driver side floor board is rusted really bad. it has become seperate from the body of the car
Old Apr 24, 2012 | 06:41 PM
  #169
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: tbi questions
with just headers a 3" exhaust an open filter my 305 tbi run out of fuel at 3275 wot after tuning with the ebl flash on stock fuel pressure . so thats about a 25-35 hp gain with very few mods . best mod to my car so far ...
Old Apr 24, 2012 | 06:48 PM
  #170
Car: 89 Formula
Re: tbi questions
350 carb. story and pics to follow.
heres a list.
750 double pumper
***** thumpr cam
gear drive
ported heads
Old May 2, 2012 | 08:57 PM
  #171
Car: 89 Formula
Re: tbi questions
its been a while since i posted but i have a lot of pics. i pulled my 305 and 700r4 i now have a 350 short block im rebuilding as a 355. i also have the 750 carb. im going to have the 700r4 rebuilt with a stage 2 shift kit. i will post pictures soon of my progress. i have a lot of old parts to sell
Old Oct 19, 2019 | 02:54 PM
  #172
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Re: tbi questions
Old Oct 21, 2019 | 05:00 PM
  #173
Schurkey's Avatar
Re: tbi questions
Originally Posted by 1986BANDIT
Why would you drag up a thread this old, so you can add NOTHING USEFUL?
Old Oct 21, 2019 | 09:13 PM
  #174
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Re: tbi questions
i added a question mark because you cant delete a comment.get it?
get yourself a job instead of being a forum cop,it makes you an annoyance.
im kind of sick of whining a-holes and unwanted opinions(one in the same)
Old Oct 21, 2019 | 09:32 PM
  #175
Schurkey's Avatar
Re: tbi questions
Translation: I screwed up but I'm too proud to apologize. Better to attack someone else instead.
Old Oct 22, 2019 | 11:26 AM
  #176
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Re: tbi questions
Bud,did i specifically call you out for anything? i left a question mark on a thread because i couldn't delete a mis-post.
did i add anything to the thread? if anyone is attacking someone its you,maybe stand back and take a look at how
it played out,self realization will do . an apology isn't necessary but would be appreciated.
in the future if someone adds something to an old thread or happens to post,if it doesn't apply to you just let it go,ok friend?
F404MECH
Oct 7, 2009 12:34 PM
marballfire
May 28, 2009 11:00 AM
Ahisto_17
Jul 3, 2007 02:37 PM
dudester
Apr 20, 2005 06:34 PM
MrJ
Feb 13, 2001 02:01 PM
