whats cheapest way to take revlimiter off???????
Old Feb 1, 2012 | 09:25 PM
Rondeezzee310's Avatar
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
What's up world I haven't bought the ebl flash because a buddy of mine just bought a 2008 charger that had a revlimiter.He said he had the revlimiter taking off without changing ecm's. So my question is can I take the revlimiter off of my Stock computer because I'm gonna change motors soon but the governor is killing. The reason for this is because I changed rearends so the speedometers hits the limiter. If I need to fix the speedo gearing to match the Rearend that's fine I just don't know where to start at.
Old Feb 2, 2012 | 12:15 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: whats cheapest way to take revlimiter off???????
You will need a new chip burned to RAISE the rev limiter. Do not remove it. If your friend removed his, he is a idiot and deserves the demise which his engine will fall too. The limiter is there for a reason.
Old Feb 2, 2012 | 12:29 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The correct way is to fix the gears so that the speedo reads correctly & the ECM really knows the true speed.
HOWEVER....If you spend over $3 to do this bypass, you've spent too much to bypass the Speed Limiter to TEMPORARY use.
http://www.austinthirdgen.org/index.php?pid=7
Old Feb 2, 2012 | 03:26 AM
Car: 91 rs camaro
Engine: 305 v8
Transmission: 700r
Axle/Gears: 373
That sounds cool ill pull it out this weekend. Now talking about the chip what other benighted will I get for my car if I bought that instead of the switch. I don't killing two birds with one stone if ill get a benefit from buying the chip.
Orr89RocZ
Apr 25, 2016 08:28 AM
88CamZ
Oct 8, 2015 10:29 AM
Damon
Sep 26, 2015 04:29 PM
dutch930
Sep 11, 2015 06:58 AM
angel2794
Sep 8, 2015 06:22 PM
