GMPP Vortec TBI Intake Throttle Bracket
Old Mar 19, 2012 | 12:56 PM
3GEN90's Avatar
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
Hi All:
Can someone who has used this intake post some pics of the throttle bracket they made, or the parts they used? The stock doesn't work fit right. I have a WC-T5 with cruise control.
thanks!
Old Mar 19, 2012 | 01:25 PM
Ronny's Avatar
Re: GMPP Vortec TBI Intake Throttle Bracket
Summit has an adjustable bracket. I used one on my holley projection manifold.
Old Mar 19, 2012 | 07:11 PM
3GEN90's Avatar
Axle/Gears: 3.08
what is part number?
tks!
Old Mar 20, 2012 | 09:11 AM
Ronny's Avatar
Actually Summit may that three. sorry dont know the part #. I would look at their site or call 1-800 Summit
Old Mar 20, 2012 | 10:58 AM
morgsie's Avatar
I'm working on a bracket for my Edelbrock RPM Performer on Vortec heads right now. It looks like you can use your stock bracket. For the rear part you will have to bend and drill new hole and the front part will bolt to the boss for the coil bracket. I have to be more percise because I am running a TV cable for my 700r4 (geometry has to be checked for proper operation). But since you are running a manual this should not be an issue. The bracket from edelbrock is wrong and is for the older carb linkage FWIW.
Old Mar 22, 2012 | 09:50 PM
CAMAROSKI's Avatar
Car: 92 camaro RS
Engine: LO3
Axle/Gears: 4gen 3.23 PBR
Hi
I saved this post when i was looking for bracket to keep my CC
https://www.thirdgen.org/forums/tbi/...tec-heads.html
Old Mar 24, 2012 | 05:49 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
My stock bracket worked just fine? I have a 350 700R4. See pic below, not the best for throttle bracket use. All you have to do is drill a new hole in the bracket, so it will use the intake manifold bolt to hold it down.
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
