Throttle Linkage With Vortec Heads?
Old Nov 6, 2011 | 12:02 AM
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
What kind of bracket are you guys using with your vortec heads? Is there one I should look at buying or do most just modify the stock bracket? I'll be running the Performer RPM for vortec heads (p/n 7116) if it makes any difference. Pictures would be appreciated. Thanks!
Old Nov 6, 2011 | 01:59 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Throttle Linkage With Vortec Heads?
The heads shouldnt change the throttle bracket you'd need....the throttle bracket bolts onto the intake I think the perofmer rpm will be missing the holes for the one side where it share's a mounting hole with the coil. but some clever fabrication would cure that id say.
Old Nov 6, 2011 | 09:02 AM
skinny z's Avatar
Because the intake bolts to the heads with vertical fasteners rather than the conventional angle, a unique bracket is required.
http://www.summitracing.com/parts/EDL-8032/
Old Nov 6, 2011 | 01:39 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I ended up using just the base portion of this and modified the stock bracket to work with it. The location for the cruise cable was wrong and the hole was too big (yes, I kept my cruise control but it needs fixed). I also used this bracket to anchor the EGR tube which runs from my #7 header primary up to the intake, which is also Vortec. In the second pic, you can see where I cut the mounting tab off the stock bracket, then drilled a hole in the side to attach it to the base of the Vortec bracket.
Old Nov 6, 2011 | 01:54 PM
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
Awesome! Exactly what I was looking for. I wasn't having any luck using search (not that I'm the best at finding info on the internet anyway). Thanks.
Old Nov 6, 2011 | 02:03 PM
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
Thanks for pointing that out. That was the reason I was excited to find out about the Edelbrock bracket because I wanted to keep my cruise control. Too bad it doesn't work out of the box. At least that sounds easy enough to rig up though. Any other issues with it that I should be aware of? The tv and throttle cables mount up without issue?
Old Nov 6, 2011 | 03:07 PM
Al Hasse's Avatar
I can't vouch for the throttle valve cable since my manual transmission doesn't use one. Doing it this way though, I don't see a reason why there would be a problem with any of the stock cables, it is the stock bracket, just mounted different.
Old Nov 6, 2011 | 06:54 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
sorry for the mis information. I didnt really think the intake bolts went a different way my bad.
Old Jan 22, 2012 | 04:01 PM
bigjcfiredog's Avatar
Car: 91 RS
Engine: Vortec 350 TBI
Subscribing. Great photo and info for my sons reconstruction.. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
