tbi slight problems while cruising..
Old Mar 22, 2012 | 09:48 PM
Spike_Akers's Avatar
Car: 83 camaro z28, 92 xj
Engine: 305 Crossfire (lu5)
Axle/Gears: richmond gear 3.73:1
ok so ive got an 89 burban (i know i know, but this site seems to be the best for info on tbi) and when cruising at about mid throttle it sometimes has a slight hesitation (feels like that first misfire you get when running out of gas)... i cant figure out any specific things that make it happen yet as it doesnt happen continuously.. has anyone ever felt this? its a 350tbi with a th400.. i've never really worked with tbi so im just wondering what you guys might think..
Old Mar 23, 2012 | 01:26 AM
Schurkey's Avatar
Re: tbi slight problems while cruising..
1988 K1500. Misfired at highway speed. Got worse as time went on. (Several months) Misfired at progressively lower speeds. Eventually stalled at idle. Took maybe 6 months to progress that far.
"Fix" was to replace distributor main shaft (or install replacement distributor)
Old Mar 23, 2012 | 01:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Check basics, make sure your ignition is up to par. New spark plugs, wires aren't burnt. Cap and rotor are not corroded beyond optimal use. You can pop off the air cleaner and fire up the motor and look for a nice cone shaped fuel spray while your at it.
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
