Getting a NEW 86 Z28..wat are some good upgrades..
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So ima be getting a 86 z28 its a 305 with a manual transmission.I just wanna know what are some good upgrades that are reasonable and wont cost me $1000's of dollars.
ohhh and by the way its a carburated engine. I was also wondering what type of engine it is and the power output on it,thanks, if anyone knows.
The engine is all stock.
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
Re: Getting a NEW 86 Z28..wat are some good upgrades..
Can't help you with the numbers for the carb'd motor but I can assure you it can be found in the thirdgen data sheets for the '86s.
I've also personally seen at least 5 other threads just like this one so check out those.
While I'm here though, a good cam and nice exhaust won't set you back too much and will make a noticeable difference. But if you do too much you'll need to re-tune.
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
That would be an LG4, putting out 165hp, 250ft-lbs torque stock.
Exhaust and carb tuning should bump you up about another 30-50hp. If it's all stock and in good condition I'd give some consideration to restoring it (with exhaust modded, of course- the exhaust systems on these cars are simply asphyxiating)
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Start with some sort of cool air intake for that carb. Routing it from the front to carburetor is best but you can do what I did and use a open element like you see on many cars and its something that can be done now ,plus its fairly easy to do.
Ghettobird52
Jul 5, 2024 11:18 PM
