tbi on carb intake now high idel
Re: tbi on carb intake now high idel
spray brake clean around the bottom of the tbi and adaptor. and also around the intake to see if you have a leak.
and once you get it sorted out lemme know how it runs. also how much higher does it sit now.
is it throwing any codes? sounds as though the tbi or adaptor have a vacuum leak. or an intake gasket is leaking. or you have a vacuum line off somewhere.
cool that you found it. now get if fixed and enjoy it. hey how much higher does the air cleaner sit now with that combo. does it still fit under a stock hood.
