where does this go
Old Apr 5, 2012 | 12:01 PM
bearterror23's Avatar
Car: 1989 base firebird
Engine: 305 tbi
Transmission: t-5
Axle/Gears: no idea
where does this go
Can anyone tell me where the rubber hose in the picture goes. I can't seem to find where in plugs into. the car is a 89 firebird with a 5 speed if that helps. Sorry if the pictures suck but i only had my phone on me.
Attached Thumbnails where does this go-image.jpg   where does this go-image_2.jpg
Old Apr 5, 2012 | 12:14 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: where does this go
it goes to the air cleaner assembly for the inlet vac motor
http://www.chevythunder.com/fuel%20i...um%20lines.htm
Old Apr 5, 2012 | 12:17 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i was wrong.
Old Apr 5, 2012 | 01:32 PM
Engine: 305 tbi
Transmission: t-5
Axle/Gears: no idea
thanks tuned i would never had figured that out
Old Apr 5, 2012 | 07:38 PM
Engine: 305 tbi
Transmission: t-5
Axle/Gears: no idea
i got another question i need help with. i found this while trying to figure out what's wrong with my car.
it looks like a sensor. it's located on the passenger side under the exhaust manifold. The 2nd pic is thge part that broke off.
So my 1st question is what is it?
And the 2nd is what problems would this being broke cause?
thanks again
Attached Thumbnails where does this go-image_4.jpg   where does this go-image3.jpg
Old Apr 5, 2012 | 07:47 PM
Engine: Lb9
Transmission: M20
coolant fan switch plug. If the fan is not rewired this is what controls it to turn on.
Old Apr 5, 2012 | 07:51 PM
Engine: Lb9
Transmission: M20
AC Delco pt308 or gm 12102621
